LIAN LI Releases Fully Reversible O11D EVO RGB Case with Two Motherboard Installation Modes, L-Shaped RGB Light Strips, Secondary Chamber, and Other Key Features
Image: LIAN LI
LIAN LI Industrial Co. Ltd., a leading manufacturer of chassis and PC accessories, launches the latest addition to its O11 series with the O11D EVO RGB. As the name suggests, the O11D EVO RGB has two built-in L-shaped RGB strips for beautifully accented lighting personalization. Inspired by the community feedback, the O11D EVO RGB includes multiple improvements such as a flexible motherboard adjustable to 2 positions, support for up to 420mm radiator at the top, and a redesigned second chamber to provide more room and modularity for the cable management solution. The O11D EVO RGB is available in black and white at an MSRP of $159.99 and $169.99 respectively.
LIAN LI O11D EVO RGB Key Features
  • L-shaped diffused RGB with improved built-in lighting control
  • Removable support column for an unobstructed view
  • Adjustable motherboard height for more radiator/fan clearance at top or bottom
  • Supports up to 420mm radiator on top, and 360mm radiator on side and bottom
  • Redesigned cable management solutions with protruding PSU bracket and HDD cages
  • Fully reversible with just a few steps
LIAN LI O11D EVO RGB Specifications
L-shaped Diffused RGB Light Strip Design on Top and Bottom
The LIAN LI O11D EVO RGB features two L-shaped diffused RGB strips on both the upper and lower panels. These two RGB strips can be easily adjusted using the buttons located on the main I/O panel, allowing for quick toggling between fourteen different modes. Users can also adjust brightness levels across five settings and choose from a diverse range of color options.
Users can opt for the high mode, which offers generous spacing at the bottom for radiators and fans with a maximum height of 45.3mm. The low mode on the other hand provides a clearance of 83.2mm on the top. In addition to the flexible motherboard solution, users can benefit from a support of up to a 420mm radiator at the top, and a 360mm radiator at the side and bottom. Top, side, and bottom all support the installation of up to 3 x 140mm fans each, all on a quickly removable bracket for ease of installation.
Unmatched Flexibility Within the Secondary Chamber
In the secondary chamber, a magnetic cable management bar allows easy access and tidy cable arrangement. The protruded PSU mounting bracket provides an extra 15mm clearance. Two modular drive cages are situated above the PSU, removable if not in use, creating additional space for mounting a fan hub or a controller. Lastly, the LIAN LI O11D EVO RGB is furnished with a dual-layer cable clip and multiple Velcro straps and tie points, providing a comprehensive and easy-to-work-with cable management solution.
More Options to be Seen
In just a few easy steps, the O11D EVO RGB allows the user to transition the traditional right-side orientated case structure into a left orientation, suiting different setup configurations and needs. The support pillar located on the left side of the front panel is now detachable, offering consumers a cleaner and more streamlined view. Additionally, the O11D EVO RGB is compatible with the existing O11D EVO vertical GPU kit and upright GPU kit. A new version of the front panel mesh kit is also available with support for 120mm, 140mm, and 160mm fans.
Availability
The O11D EVO RGB is available on December 21st, 2023, at an MSRP of $159.99 for the black, and $169.99 for the white version.
The O11D EVO RGB is now available at Newegg:
Black: https://www.newegg.com/p/2AM-000Z-000C0?Item=9SIAFSTK677375
White: https://www.newegg.com/p/2AM-000Z-000C1?Item=9SIAFSTK677379
The O11D EVO RGB is now available at Overclockers UK: https://www.overclockers.co.uk/lp/lian-li-o11-evo-rgb
The O11D EVO RGB is now available at Caseking: https://caseking.de/o11d-evo-rrgb
Image: LIAN LI
Image: LIAN LI
