Kohler Will Be Showing Off Its Voice-Controlled Smart PureWash E930 Toilet Seat at CES 2024
Image: Kohler
As AI continues to conquer the surface world and beyond other smart technology is looking to expand in the under nether regions of humanity. While smart toilets have been popping up over the years those looking for a slightly less expensive option may be in luck as Kohler will be showing off its PureWash E930 “hands-free” bidet at CES 2024. Jokes aside the PureWash E930, which Kohler is currently selling for almost $1,000 off its retail price at $1,289.40, packs some luxurious options into its design. From self-cleaning, including UV light disinfecting, a motion-activated cover, remote control, adjustable water temperature, heated seat, grip-tight seat bumper, a more gentle child mode, and more, this bidet has you and the family covered. As if that isn’t enough you can “Hey Siri. . .” or “Hey Alexa. . .” for further personal assistance in the hands-free experience.
According to Engadget, Kohler will be showing off the PureWash E9300 at CES 2024 so those interested in a high-tech bathroom adventure should stop and check it out. Even as it normally retails for $1K-$2K the PureWash E9300 still markets for much less than Kohler’s full-on smart toilets which retail for up to $10,000.
Features (via official product page):
  • Continuously heated water for consistent comfort
  • Front and rear wash modes provide warm water for cleansing
  • Adjustable water temperature and water pressure
  • Choose oscillating or pulsating spray
  • Sleek, handheld remote control with two programmable user presets
  • Self-cleaning function uses UV light to automatically clean the wand surfaces
  • Motion-activated, hands-free opening/closing of cover
  • Bowl is automatically misted prior to use for more effective rinsing while flushing
  • Boost spray automatically adjusts rear spray mode to highest pressure
  • Child mode with soft, gentle wash provides a safe experience
  • Heated seat with adjustable temperature settings
  • Warm-air drying system with adjustable temperature settings
  • Automatic deodorization function for odor control
  • LED lighting illuminates the bowl to serve as a nightlight
  • Energy-save function
  • Ergonomically designed for comfortable seating
  • Quiet-Close™ elongated lid and seat prevents slamming
  • Quick-Release™ functionality allows seat to be removed easily from toilet for convenient cleaning
  • Grip-Tight bumpers hold seat firmly in place
  • Toilet seats are not returnable to Kohler Co. if opened or outside of original packaging
  • Fits most elongated toilets
