MSI MEG 321URX QD-OLED Monitor Features RGB Health Bar and AI Tech for Instantly Detecting Enemies
Image: The FPS Review
MSI has unveiled a new 32-inch 4K 240 Hz QD-OLED gaming monitor at CES 2024 called the MPG 321URX, and it includes a technology called “AI Skysight,” which users can enable to “instantly detect” on-screen enemies. Other features include trainable AI models, supported by firmware updates, and an RGB spectrum bar on the bottom of the display that changes based on player health.
Unique features:
  • AI SKYSIGHT
    • Enemy and friendly identification, head-up display
      • Equipped with mini-map Auto-Scan technology, the monitor scans your game’s mini-map to instantly detect enemies and shows its direction as an HUD, giving you the strategic edge you need for total gaming awareness.
  • HEALTH INDICATOR SPECTRUM BAR
    • Image recognition, spectrum bar
      • Designed to auto-detect the game while you’re immersed in gaming, the monitor projects health onto the Spectrum Bar in corresponding colors, seamlessly integrating your health status and allowing you to stay focused on the action without missing a beat.
  • AI UPGRADE POSSIBILITY
    • Trainable AI models, firmware update
      • The adventure of AI eliminates the constraints previously imposed across different games. When MSI offers well-trained AI modules, such as Health Indicator Spectrum Bar, users can leverage Gaming Intelligence to conduct local training for their preferred games. First, collect your own data depending on the games you play, including images and footages, to train your custom models. Consequently, coupled with MSI firmware update, these custom-trained AI models can be seamlessly integrated into your monitor, significantly enhancing usability across various scenarios and games.
Feature list:
  • 32-inch / QD-OLED / 3840×2160 (4K) / 240 Hz / 0.03 ms (GtG)
  • A.I. SkySight utilizes AI technology to automatically detect the enemy’s position and display it on the screen.
  • OLED Care 2.0 adds more detection ways to reduce OLED scree burn-in
  • Optimized thermal solution with Graphene film and custom heatsinks ensures efficient, silent heat dispersion
  • VESA Certified DisplayHDR True Black 400 & ClearMR 1300
  • Gaming Intelligence app by AI technology
  • SpectrumBar with Mystic Light and Glow Sync provides a soft ambient light
  • HDMI 2.1, DisplayPort 2.1, Type C (DP Alt. with 90W PD), USB 2.0, Headphone-out (*Supports Display Stream Compression)
MSI has already listed a similar monitor called the MPG 321URX QD-OLED, which mentions “AI Vision” as one of its key features.
Source: MSI
