COLORFUL Introduces NVIDIA GeForce RTX 40 SUPER Series GPUs with Detachable LCD, Illuminated Gravity Rim for “Mysterious Black Hole Effect”
Image: COLORFUL
COLORFUL has announced that it its lineup of GPUs is expanding with 13 new GeForce RTX 40 SUPER Series models. One series, the iGame Vulcan, includes a unique feature in the form of a removable display, while the iGame Advanced Series features an illuminated Gravity Rim on the center fan, something that the company says provides a “mysterious black hole effect.” The iGame Neptune will also be available for those seeking a GPU with an AIO liquid-cooling solution.
iGame Vulcan Series features:
  • One-Key Overclock: A conveniently placed button located at the rear I/O that activates overclocking function for a quick and easy performance boost without opening software.
  • Hurricane Scythe Blades: Three Hurricane Scythe Blade fans delivering fan heat dissipation with its improved airflow compared to the previous-generation fan blade design.
  • iGame Smart LCD: A removable magnetic display that can be mounted on the graphics card or on the included display dock. The display has a resolution of 800x216px – fully customizable via the iGame Center app to display real-time monitoring figures, custom images, GIFs, and others.
  • Display Dock: The display dock is an external docking accessory that users can place on their desk or on top of the chassis that holds the iGame Smart LCD. The display dock connects the display via a USB cable.
  • Vulcan Support Frame: The Vulcan Support Frame enhances the stability and structural rigidity of the entire graphics card. This eliminates the risk of bending and warping as it supports the weight of the card.
  • Hollow Back Panel: A hollow back panel design that allows airflow to freely pass-through the heatsink. This design greatly improves heat dissipation compared to conventional GPU air cooling designs.
  • iGame Accessories: The Vulcan Series comes with a set of accessories including the Screen Wipes, White Gloves, and Screwdriver.
iGame Vulcan Series specs:
iGame Neptune Series features:
  • Slim 2-Slot Form Factor: Slim 2-slot PCI thickness that will fit in most PC builds.
  • Liquid Cooled: Harness the superior cooling performance of liquid cooling for higher overclocks at lower noise levels.
  • Full-Cover copper Waterblock: High-performance full-cover copper waterblock that covers the GPU, memory, and other critical components in the graphics card.
iGame Neptune Series specs:
iGame Advanced Series features:
  • Gravity Rim: A redesigned version of the iGame Energy Core that creates a mysterious black hole effect.
  • Meteorite Backplate: A sturdy metal backplate that reduces PCB flexing. An intricate iGame grille design is added to the backplate’s hollow back to add aesthetics.
  • Hurricane Scythe Blades: New fan blade design that delivers superior airflow compared to the previous-generation Storm Chaser fan design. The Advanced Series uses a triple-fan cooler design with a larger central fan with Gravity Rim.
iGame Advanced Series specs:
iGame Ultra W Series features:
  • ULTRA Retro RGB: Eye-catching and visualizing with the combination of the holographic shroud design and RGB lighting.
  • ULTRA Cooling: A triple-fan cooler design with a high-performance heatsink for fast heat dissipation. The 4080 SUPER Ultra W sports seven composite heatpipes (5x6mm+2x8mm), 4070 Ti SUPER packs six heatpipes (6x6mm), and the 4070 SUPER packs four heatpipes (4x6mm).
  • Customizable RGB Lighting: RGB lit ULTRA design fully customizable using the iGame Center software.
iGame Ultra W Series specs:
Battle-Ax (NB EX) Series features:
  • Battle Ax Backplate: Improved backplate design that provides structural rigidity and passive heat dissipation.
Battle-Ax (NB EX) Series specs:
Press release:
Colorful Technology Company Limited, a leading brand in gaming PC components, gaming laptops, and Hi-fi audio products, launches its lineup of the new NVIDIA RTX SUPER Series graphics cards. Included in the lineup at the GeForce RTX 4080 SUPER 16 GB, GeForce RTX 4070 Ti SUPER 16 GB, and GeForce RTX 4070 SUPER 12 GB graphics cards featuring the Vulcan, Neptune, Advanced, Ultra W, and Battle-Ax Series models. The new NVIDIA RTX 40 SUPER Series graphics cards will be using the new 12v-2×6 connector standard, an improved version of the 12VHPWR connector.
iGame Vulcan Series
Following the popularity of all-white gaming PC builds, COLORFUL kicks off the SUPER Series with the iGame Vulcan and Vulcan W models. The Vulcan Series features the iGame Smart LCD, a removable display that users can place on the graphics card or on the included display dock. The iGame Smart LCD provides creative personalization for your gaming setup wherein it can display real-time monitoring status, images, or GIFs. Aside from the flexible and customizable display, the iGame Vulcan Series sports RGB lighting, fully customizable via the iGame App.
The iGame Neptune Series features a high-performance all-in-one liquid thermal solution that enables higher overclocks at low noise levels. The 4080 SUPER comes equipped with a 360 mm radiator while the 4070 Ti SUPER comes with a 240 mm radiator. The liquid cooling solution delivers exceptional heat dissipation while downsizing the graphics card to a compact 2-slot form-factor. The iGame Neptune Series graphics cards sports RGB lighting, fully customizable via the iGame App.
The iGame Advanced Series features a sleek black on silver color scheme with an eye-catching illuminated Gravity Rim on the larger central fan. The iGame Advanced Series graphics cards sports RGB lighting, fully customizable via the iGame App.
Amongst our popular series of graphics cards, the iGame Ultra W Series features the iconic holographic Retro Pop Art design and a triple-fan thermal solution. The iGame Ultra W Series graphics cards feature RGB lighting, fully customizable via the iGame App.
COLORFUL Battle-Ax (NB EX) Series
The Battle Ax, also known as NB-EX Series sports an eye-catching black and red design. The NB-EX SUPER Series uses a high-performance triple-fan cooler for exceptional cooling.
Source: COLORFUL
Via: Guru3D
