Corsair Launches Its Most Powerful and Efficient CPU Air Cooler Ever
Image: Corsair
Corsair has announced the availability of the A115, a new high-performance tower CPU air cooler that the company says is its most powerful and efficient air cooler ever. The cooler features Corsair’s Slide-and-Lock fan mount system, which allows users to “adjust the height of the fans tool-free to easily accommodate nearly any DRAM module on the market – or replace your memory on the fly.”
Editor’s Note – We also got to see this in action at CES see below pictures and more in our CORSAIR CES article.
Features:
  • Precision engineered convex copper cold plate optimized for latest CPUs
  • Fits Intel LGA-1700 and AMD AM5 sockets and older
  • Two AF140 ELITE fans with CORSAIR AirGuide technology
  • Compatible with 3000 | 4000 | 5000 | 7000 Series cases
  • Dimensions (L x W x H): 153mm x 155mm x 164.8mm
  • Five-year warranty
Pricing and availability:
  • Available now from the Corsair webstore and authorized retailers
  • $99.99 USD MSRP
Quotes:
“Our customers have been clamoring for a new CORSAIR air cooler, and we’ve heard them loud and clear,” said Aaron Neal, Director of DIY Product Marketing at CORSAIR. “We knew we needed to make our mark with the A115, so we continued refining our design until we were satisfied that we could deliver a best-in-class air cooling solution to our enthusiast customers. The end result speaks for itself.”
Press release:
CORSAIR, a world leader in high-performance gear and systems for gamers, content creators, and PC enthusiasts, today announced the launch of the A115 High-Performance Tower CPU Air Cooler, the latest addition to its CPU cooling lineup. Meticulously engineered to tame the high temperatures generated by the latest Intel and AMD processors, the A115 is the most powerful and efficient air cooler that CORSAIR has ever produced – with innovative features that make installation and adjustment incredibly easy.
Image: Corsair
At the heart of the A115 are six 6mm heat pipes and a high-efficiency copper cold plate, capable of handling CPUs with up to 270W TDP. The slightly convex shape of the cold plate optimizes contact with the CPU, ensuring maximum thermal transfer and stability. After absorbing heat, 90 nickel-plated cooling fins provide a substantial 1.69m² surface area for rapid heat dissipation.
Image: Corsair
The A115 is equipped with two CORSAIR AF140 ELITE Fans, featuring AirGuide technology with anti-vortex vanes that deliver concentrated airflow. These high-performance fans max out at 1,600 RPM while generating a low 33.9 dBA of noise thanks to their fluid dynamic bearings. CORSAIR’s innovative Slide-and-Lock fan mount system, now slimmer than ever, features a tool-free ratcheting mechanism that enables variable mounting height for broad DRAM height compatibility, making it a breeze to replace your memory module.
Image: Corsair
To ensure a secure fit on high-performance CPUs, the A115 is engineered with the CORSAIR HoldFast 2.0 Retention System, including brackets for the latest Intel LGA 1700 and AMD AM5/AM4 sockets. Pre-applied with CORSAIR’s top-performing XTM70 thermal paste, the cooler is ready to install with optimal heat transfer right out of the box.
Image: Corsair
Image: Corsair
If you’re looking to build an air cooled PC with a top-of-the-line CPU, pick up the A115 to ensure that your cooling can keep up.
Source: Corsair
