ASRock Launches AMD Radeon RX 7600 XT Steel Legend and Challenger Series Graphics Cards
Image: ASRock
ASRock has launched the Radeon RX 7600 XT Steel Legend and Radeon RX 7600 XT Challenger, two new graphics cards based on AMD’s latest addition to the RDNA 3 family. These cards boost up to 2,810 MHz and 2,799 MHz, respectively, while some of the unique features for the Steel Legend, the more premium model, includes a triple-fan thermal design with striped axial fans and ARGB LEDs.
AMD Radeon RX 7600 XT Steel Legend 16GB OC specs/features:
  • Clock: GPU / Memory
    • Boost Clock: Up to 2810 MHz / 18 Gbps
    • Game Clock: 2539 MHz / 18 Gbps
  • Key Specification
    • AMD Radeon RX 7600 XT GPU
    • 16GB GDDR6 on 128-Bit Memory Bus
    • 32 AMD RDNA 3 Compute Units (with RT+AI Accelerators)
    • 32MB AMD Infinity Cache technology
    • Microsoft DirectX 12 Ultimate
    • PCI Express 4.0 Support
    • 2 x 8-pin Power Connectors
    • 3 x DisplayPort 2.1, 1 x HDMI 2.1
  • Key Features
    • Polychrome SYNC
    • Triple Fan Design
    • Stylish Metal Backplate
    • Striped Axial Fan
    • 0dB Silent Cooling
    • Ultra-fit Heatpipe
    • Super Alloy Graphics Card
Image: ASRock
AMD Radeon RX 7600 XT Challenger 16GB OC specs/features
    • Boost Clock: Up to 2799 MHz/ 18 Gbps
    • Game Clock: 2516 MHz/ 18 Gbps
  • Key Specification
  • Key Features
    • Dual Fan Design
    • Axial Ring Fan
    • LED Indicator
Image: ASRock
Press release:
The new ASRock AMD Radeon RX 7600 XT Steel Legend and Challenger Series graphics cards are built on the advanced AMD RDNA 3 architecture, featuring up to 32 redesigned compute units and second-generation AMD Infinity Cache technology. They also offer the latest features and capabilities including AMD Radiance Display Engine, full AV1 encoding and more to power high-performance 1080p gaming, streaming and content creation applications. Meanwhile, with support for AMD HYPR-RX with AMD Fluid Motion Frames users can crank up their game settings for fully immersive and highly responsive gaming.
The new ASRock AMD Radeon RX 7600 XT Steel Legend and Challenger Series graphics cards are equipped with high-speed 16GB GDDR6 memory at 18Gbps and are pre-overclocked to deliver higher levels of performance. The AMD Radiance Display Engine provides 12-bit-per-channel color for up to 68 billion colors for incredible color accuracy.
In addition, ASRock AMD Radeon RX 7600 XT Steel Legend and Challenger Series graphics cards also support various ASRock exclusive features such as the Striped Axial Fan, the Ultra-fit Heatpipe, a stylish metal backplate, and Polychrome SYNC technology to provide excellent cooling efficiency, solid construction, and fancy ARGB lighting effects. Powered with these exclusive features, ASRock AMD Radeon RX 7600 XT Steel Legend and Challenger Series graphics cards are ideal choices for 1080p gamers and content creators.
ASRock AMD Radeon RX 7600 XT Steel Legend 16GB OC Graphics Card
The ASRock AMD Radeon RX 7600 XT Steel Legend 16GB OC graphics card for white-themed PC builders achieves an astonishing Boost Clock of up to 2810 MHz. The triple-fan thermal design with the unique Striped Axial Fan and Ultra-fit Heatpipe provide great heat dissipation, the Stylish Metal Backplate strengthens the structure and prevents the plate from bending, and the Super Alloy Graphics Card components provide stability for long-term operation. These useful features, along with factory pre-overclocking, make the ASRock Radeon RX 7600 XT Steel Legend 16GB OC graphics card a premium choice in its class.
ASRock AMD Radeon RX 7600 XT Challenger 16GB OC Graphics Card
The mainstream ASRock AMD Radeon RX 7600 XT Challenger 16GB OC offers a Boost Clock of up to 2799 MHz. It’s equipped with a newly-designed stylish dual-fan cooler, the exclusive Axial Ring Fan, and Ultra-fit Heatpipe to provide efficient heat dissipation. The LED indicator makes the graphics cards more eye-catching. The metal backplate strengthens the structure. The high-quality Super Alloy Graphics Card components provide more stable operation. The factory default overclocking settings deliver higher performance. These practical designs make the ASRock AMD Radeon RX 7600 XT Challenger 16GB OC become an essential component for system integrators and mainstream users.
Source: ASRock
