ASUS and Noctua have expanded their partnership with the GeForce RTX 4080 SUPER 16GB GDDR6X Noctua OC Edition, a custom version of the new SUPER GPU from NVIDIA that features a pair of Noctua NF-A12x25 PWM fans for what ASUS has described as “exceptional cooling and low noise.” Users can expect to find boost clocks of up to 2,640 MHz with this graphics card, alongside other key features that include an optimized vapor chamber.
Features:
- Powered by NVIDIA DLSS3, ultra-efficient Ada Lovelace arch, and full ray tracing.
- 4th Generation Tensor Cores: Up to 4X performance with DLSS 3 vs. brute-force rendering
- 3rd Generation RT Cores: Up to 2X ray tracing performance
- OC Edition: 2640 MHz (OC mode)/ 2610 MHz (Default mode)
- Two Noctua NF-A12x25 PWM fans deliver exceptional cooling and low noise.
- Optimized vapor chamber efficiently wicks heat into a large fin array
- Dual BIOS switch lets you toggle between Quiet and Performance BIOS profiles sans software.
- 0dB technology lets you enjoy light gaming in relative silence.
- GPU Tweak III provides intuitive performance tweaking, thermal controls, and system monitoring.
Connectivity:
- 2x HDMI 2.1a
- 3x DisplayPort 1.4a
Other GeForce RTX Noctua Editions include:
- ASUS GeForce RTX 3070 Noctua Edition
- ASUS GeForce RTX 3080 Noctua Edition
- ASUS GeForce RTX 4080 Noctua Edition
Noctua on its custom GeForce RTX 4080:
…the reduction in noise levels is as big as 14.9 dB(A). At medium fan speeds (70% PWM), the Noctua Edition runs 16.8 dB(A) quieter while being fractionally hotter (0.8°C). The picture at low fan speeds (such as at typical auto settings with 23°C ambient temperature) is similar with near-identical temperatures and a reduction in noise levels of 4.8 dB(A), making the already quiet original ASUS TUF Gaming card even quieter.
