CaseKing has begun selling the ST060, a new CPU cooler from Lamptron that not only features dual PWM fans with RGB, but also a 6-inch screen that can be used to display system information and more. Featuring six heat pipes, this cooler is advertised with a cooling capacity of 260 watts.
Compatibility and pricing:
- Intel Socket LGA 1366, 1200, 115X, 1700, 2011
- AMD Socket AM5, AM4
- €299.90
Features:
- Extremely powerful dual tower cooler with 260W TDP
- Six 6mm heat pipes & brackets for additional fan
- 2x PWM fans in 120 mm format
- Integrated display for playing content or monitoring temperatures
- High compatibility with AMD and Intel
- Bracket for easy installation
Specs:
- Dimensions: 153 × 152 × 120 mm (W x H x D)
- Material: copper, aluminum, plastic
- Heat pipes: 6x Ø 6 mm
- Cooling capacity: 260W TDP
Fan specs:
- 2x 120 mm PWM RGB (max. 1,500 rpm)
- Connection: 4-pin PWM
- Total volume: max. 35.3 dB(A)
Lamptron on the display:
With the integrated display, your system is guaranteed to stand out. It is located at the top of the cooler and is therefore perfectly visible. With it you can easily display and monitor videos or important data on your PC such as temperatures.
