Seasonic has produced a limited-edition version of its Vertex GX-1000 power supply that bundles 1,000 watts of output capacity in a white case with a cherry blossom design, according to new images shared by Japanese hardware site Hermitage Akihabra. This special edition, which is dubbed “Sakura,” appears to be exclusive to select retailers in Japan.
Features/pricing:
- White case with pink bottom plate
- Cherry blossom design on sides
- ATX 12 V form factor
- Fully Modular
- 80 PLUS Gold Certified
- ATX 3.0 and 16-Pin PCIe Gen 5 Cable (12VHPWR)
- 1x 12VHPWR connector
- 135 mm Fluid Dynamic Bearing Fan
- Premium Hybrid Fan Control
- Tight Voltage Regulation (12 V, 5 V and 3.3 V) [± 3 %]
- Gold Plated High Current Terminal (MB, CPU and PCIe)
- 12 years warranty
- “in the mid-30,000 yen range”
Gallery:
Seasonic on the GX-1000’s fan:
High performance Fluid Dynamic Bearing (FDB) fans are designed to take advantage of the impact absorbance effects of oil. They are extremely reliable and generate considerably less operating noise and heat than ball bearing fans. The lubrication of the bearing surface reduces friction and vibration and therefore lowers overall power consumption. Due to the effortless, quieter rotations and its robust construction, this reliable fan technology also greatly increases the lifespan of the fan.
