Sharkoon has listed the Rebel C70G and C70M RGB, two new ATX PC cases that feature what the company says is an elegant wood design on the front panel. The new cases are complemented by the SKILLER SFM12 – Wood, a new 140 x 100 cm floor protection mat that simulates a rustic wooden floor.
Product links:
Rebel C70G/C70B RGB differences:
- C70G: Tempered glass side panel
- C70B: Metal side panel
Rebel C70G/C70B RGB specs:
Rebel C70G RGB gallery:
Sharkoon on the Rebel C70G RGB:
With its elegant wood design on the front panel and screwless tempered-glass side panel, the Rebel C70G RGB adds a stylish touch to any gaming room, living room or study. Apart from a striking appearance, modular installation options allow space for up to eleven 120 mm fans or two radiators. And along with perforated surfaces in and around the case, an optimal cooling performance is ensured, even for high-end setups. In addition, the continued efficiency of the PC case is supported by its future-proof USB-C and TRRS connections.
SKILLER SFM12 – Wood gallery:
Sharkoon on the SKILLER SFM12 – Wood:
The Sharkoon floor protection mat is entering its third round! To go with this, there are now three new motif designs, where the attention is especially drawn by a 3D depth effect. Apart from its eye-catching designs, the SKILLER SFM12 floor mat stands out, above all, due to its high degree of durability and a thickness of 5 millimeters that provides reliable protection of the floor surface from scuffs and scratches.
