Corsair Launches Hydro X Series iCUE LINK XH405i RGB Custom Cooling Kit and New Water Blocks for ASUS/MSI GeForce RTX 4080 Series GPUs
Image: Corsair
Corsair has launched the iCUE LINK XH405i RGB, a new addition to the company’s Hydro X Series of custom cooling kits that bundles everything that one would need to set up an iCUE LINK-enabled CPU custom cooling system, including a high-efficiency CPU water block, 3x QX120 RGB fans, and more. Additionally, Corsair is introducing updated iCUE LINK XG7 RGB GPU Water Blocks today that fit GeForce RTX 4080 and 4080 SUPER MSI SUPRIM/GAMING TRIO and ASUS ROG STRIX/TUF Gaming cards.
Product links:
Hydro X Series iCUE LINK XH405i RGB Custom Cooling Kit features:
  • All you need for a complete CPU loop in one box
  • Simplified building and installation using iCUE LINK technology
  • Intelligently controlled, low-noise custom cooling
  • Dynamic RGB lighting across multiple components
Image: Corsair
Hydro X Series iCUE LINK XG7 RGB 40-SERIES GPU Water Block features:
  • Premium CNC machined nickel-plated copper construction
  • Effortless single cable connectivity with iCUE LINK (iCUE LINK System Hub sold separately)
  • Full-length aluminum casing and backplate
  • 16 Individually addressable RGB LEDs
Image: Corsair
Corsair on its new iCUE LINK XH405i RGB Custom Cooling Kit:
The XH405i kit, available in stealth gray or white, bundles everything you need to set up a stunning iCUE LINK-enabled CPU custom cooling system. This includes a high-efficiency CPU water block, a top-tier D5 pump/reservoir combo unit, three stunning QX120 RGB fans, a 360mm performance radiator, and more. Taking advantage of the game-changing iCUE LINK ecosystem that vastly reduces the complexity of component connections, the XH405i makes custom cooling a genuinely accessible hobby for enthusiasts of all levels – not just the most dedicated builders.
The XC7 RGB ELITE CPU Water Block delivers extreme cooling performance with a premium copper cold plate and hexa-flow cooling engine. It is compatible with a wide range of Intel and AMD® processors, supporting LGA 1700 and AM5 / AM4 sockets. The XD5 RGB ELITE Pump/Reservoir Combo is powered by the widely popular D5 PWM pump and features a 440ml integrated nylon reservoir. Both units come with innovative in-loop temperature sensors that enable next-level cooling performance control thanks to the intelligent, bi-directional iCUE LINK connection. Furthermore, iCUE LINK ELITE components are now Smart, housing individual microcontrollers that manage and report performance and temperatures to the included System hub and iCUE software.
The inclusion of three QX120 RGB fans, alongside the XR5 360mm radiator, ensures optimal heat dissipation, while 148 individually addressable RGB LEDs across the entire cooling setup offer endless customization options through CORSAIR iCUE software.
Transparent XT Hardline Tubing completes your loop, easily shaped and cut to your needs with an included XT Hardline Bending Toolkit. A liter of pre-mixed clear XL8 Performance Coolant carries heat away from your CPU. The XH405i contains all the necessary XF Hardline Fittings and Adapters, with extra fittings included for those looking to expand their cooling to GPU blocks.
