Corsair has launched a white color variant of the RMx SHIFT, an ATX 3.0 power supply that is said to be the world’s first to feature a DC connector panel on the side of the unit. This PSU is available in wattages ranging from 750 to 1,000 watts and comes with a PCIe 5.0 12VHPWR cable for use with GPUs that would include NVIDIA’s GeForce RTX 40 Series.
Models/wattages:
Key features:
- ATX 3.0 certification and PCIe 5.0 compliance
- Repositioned side panel for unobstructed access to all Type 5 Gen 1 micro-fit connections
- Fully modular cabling
- 80 PLUS Gold-rated efficiency
- Premium 105°C-rated Japanese capacitors
- 140 mm fluid dynamic bearing fan
- Zero RPM mode support
A look at the original, black version:
Corsair on its new PSU:
With its repositioned side panel, builders have unobstructed access to all of its Type 5 Gen 1 micro-fit connections, making installation and maintenance painless. It also means less bending and twisting of the cables, removing unnecessary strain on the cables and connectors.
White models of RMx SHIFT address the overwhelming demand from the PC building community for more customization options to match a wider range of builds. The new white units retain all the features that have made the RMx SHIFT a market standout, including fully modular cabling, 80 PLUS Gold-rated efficiency, premium 105°C-rated Japanese capacitors, and a 140mm fluid dynamic bearing fan, while matching the clean aesthetic of white system builds.
With ATX 3.0 certification and PCIe 5.0 compliance, the RMx SHIFT Series is ready to power the latest systems, and includes a PCIe 5.0 12VHPWR GPU cable for use with modern graphics cards such as the NVIDIA GeForce RTX 40 Series.
RMx SHIFT PSUs and cables will fit in any PC case that supports ATX format and is at least 210mm (8.3″) wide. The PSU must also be accessible from the side when mounted in the case. To check case compatibility, please refer to the online CORSAIR PC Builder.
