ENERMAX Launches World’s First Dual-Standard PSU, Supporting Both ATX 3.1 and ATX12VO Standards
Image: ENERMAX
ENERMAX has introduced the PlatiGemini, a new 1,200-watt PSU that is said to be the world’s first dual-standard power supply, featuring support for not only the Intel ATX 3.1 standard, but also the ATX12VO standard. Both 19-pin and 24-pin power connectors are included with this 80 PLUS Platinum PSU, which counts 100% Japanese capacitors, optimal fanless control, and dust-free rotation (D.F.R.) technology as some of its other key features.
Store links:
Features:
  • Integrated with Both Intel ATX 3.1 and ATX12VO Standards
  • 80 PLUS Platinum Certified and 74% Efficiency at 2% Load
  • Fully Modular with Native 600W 12V-2×6 and 12VO Motherboard 10-Pin Cable
  • Up to 235% Power Excursion
  • 100% Japanese 105°C Capacitors
  • ENERMAX’s Dust-Free Rotation Technology with D.F. Switch Button
  • 60% Load Semi-Fanless Technology
  • Premium Mesh-Sleeved Cables with Cable Comb Kit Included
A closer look at its connectors:
Image: ENERMAX
ENERMAX on its PSU:
The PlatiGemini, as the world’s first dual-standard power supply, supports both 24-pin mainstream motherboards and 10-pin energy-saving 12VO motherboards, offering versatility for current and future technological requirements. By supplying only 12 volts to the system components, the power supply eliminates the need for conversion to other voltage levels, reducing energy loss and improving overall energy efficiency. And with the support of the 24-pin mainstream motherboards, it ensures adaptability to any current or future tech needs, bridging the gap between different specifications, and being ready for sustainable computing.
The PlatiGemini is compatible with PCIe 5.1 and Intel ATX 3.1 standards, it can handle power surges up to 235% and is equipped with a native 600W 12V-12×6 cable which provides sufficient power for high-end graphic cards and demanding tasks such as content creation, virtual reality and AI. The PlatiGemini incorporates 100% industrial-grade Japanese capacitors and the power efficiency goes beyond the standards set by the 80 PLUS Platinum certification. It delivers up to 94% efficiency under typical loads and maintains up to 74% efficiency at a 2% load. This level of efficiency ensures energy savings, particularly in idle or low-load scenarios.
Equipped with a 135mm industrial-grade dual-ball bearing fan, the built-in optimal semi-fanless technology allows the fan to remain stopped until you reach 60% working load or over-temperature, improving the overall system acoustics at low and medium workloads. The PlatiGemini also features ENERMAX’s next-gen patented Dust-free Rotation (D.F.R.) self-cleaning technology, which can expel dust through instant reversal fan spin when the system is powered on. The D.F.R. function also serves as a power-on indicator, monitoring the power supply’s activation in a semi-fanless mode. Users can also manually trigger the D.F.R. function with the D.F. switch button on the power switch side for active cleaning.
