ENERMAX has introduced the ENERMAXK8, a new mid-tower ATX PC case that pairs what the company says is a sleek and sophisticated design with USB Type-C Port, built-in fan bracket within the front panel, and other features. This case is available in black and white versions.
Features:
- Thorough Visual Design Case
- High-Quality 0.7mm SPCC Case Body
- 3 Pre-Installed ARGB PWM Fans
- USB 3.2 Gen1 Type A and Gen2 Type C Compliant
- Supports 360mm AIO or 7 Fans in Maximum
- Fan Bracket Design for Easy Installation
- Enlarged Cable Manage Space
- 7 Reusable Slots for Flexible GPU Installation
- 21 Built-in Lighting Effects with Control Hub
A look at the built-in fan bracket within the front panel:
ENERMAX on its new case:
Featuring a sophisticated front panel design and robust construction, the ENERMAXK8 exudes a contemporary aesthetic with its tempered glass front and side panels, offering a sleek showcase for the internal components of your build. Equipped with three pre-installed ARGB PWM fans and a built-in 6-port control hub, users can seamlessly synchronize their ARGB components with the system lighting effects using either motherboard ARGB software or the 21 built-in lighting presets.
ENERMAXK8 incorporates clever design elements for convenient system assembly. It features a built-in fan bracket within the front panel, allowing users to effortlessly install three 120mm fans on one side of the bracket and a 360mm radiator for an AIO cooler on the opposite side. The included thumb screws can further simplify the installation process. Front panel connectivity options are one USB 3.2 Gen 2 Type C port and one USB 3.2 Gen 1 Type A port.
As part of our latest product launch campaign exclusively for the European market, customers can now purchase ENERMAXK8 from ALTERNATE and receive an additional CPU AIO cooler, the LIQMAXFLO series, at a special promotional price.
