Horizon Forbidden West Complete Edition Patch 1.0.43.0 Brings DLSS 3 Frame Generation to Cutscenes and Other Improvements to Nixxes Software’s PC Port
Image: The FPS Review
Patch 1.0.43.0, the first major update for Horizon Forbidden West Complete Edition on PC, is now rolling out to players via Steam and the Epic Games Store, Guerrilla Games and Nixxes Software have announced. This update introduces crash fixes, various bug fixes, and improvements based on player feedback, including an update to DLSS 3 Frame Generation that makes it active during cutscenes, improving performance for those with the supported hardware.
Release notes:
  • Various crash fixes and stability improvements.
  • Resolved an issue that prevented players from claiming rewards at the Hunting Grounds when using the mouse.
  • The HDR Max Luminance slider is now functioning correctly.
  • The game is now able to save when the Documents folder is rerouted to the root of a drive instead of a folder.
  • DLSS 3 Frame Generation is now active in cutscenes and while UI screens such as the weapon wheel are displayed.
  • Photo Mode now shows the correct ‘Hide UI’ button prompt when using a controller.
  • Fixed a bug that could result in multiple Quest categories being highlighted at the same time.
  • Resolved a bug that caused a mouse cursor offset on the map on resolutions other than 1920×1080 pixels.
Nixxes on the patch and what’s coming:
We’ve…fixed several bugs, including one that prevented players from claiming rewards at the Hunting Grounds when using mouse and keyboard controls. This patch also fixes the HDR Max Luminance slider and enables DLSS 3 Frame Generation during cutscenes. Check out the release notes below for more details.
We are aware of other issues raised by the community and are actively working on future patches with further bug fixes and optimizations.
