ASUS Launches ROG Keris II Ace 54-Gram Ergonomic Wireless Gaming Mouse for Pro FPS Players
Image: ASUS
ASUS has listed the ROG Keris II Ace, a new wireless ergonomic gaming mouse for pro FPS players that the company announced during CES but is now available at select retailers, including Newegg and Micro Center. Highlights of this mouse include a 54-gram weight, 42,000-dpi ROG AimPoint Pro optical sensor, ROG optical micro switches, and ROG SpeedNova, ASUS’ wireless technology for low-latency, reliable wireless 2.4 GHz RF performance and optimized energy efficiency.
Store links:
Features:
  • Lightweight 54-gram gaming mouse: Ergonomically shaped shell design is tested and approved by FPS esports professional
  • ROG Polling Rate Booster: Attach the mouse receiver directly onto the device to drive polling rates up to 4000 Hz in wireless mode and up to 8000 Hz in wired mode.
  • ROG AimPoint Pro optical sensor: 42,000-dpi optical sensor with < 1% deviation for ultimate precision, and track-on-glass capability
  • ROG Optical Micro Switches: Clicky and instant actuation, with 100-million-click lifespan
  • Tri-mode connectivity: Flexibility via wired USB, low-latency 2.4 GHz RF, or Bluetooth® mode that’s able to pair with up to three devices
  • ROG SpeedNova wireless technology: Low-latency, reliable wireless 2.4 GHz RF performance and optimized energy efficiency
  • ROG Omni Receiver: Connect to multiple supported devices wirelessly with a single receiver
  • Anti-slip mouse grip tape: Provides an assured grip and adds a bit of flair
  • ROG Paracord and 100% PTFE mouse feet: High-quality materials facilitate smooth and fast movements
  • Onboard control: Frequently used mouse settings can be adjusted directly by pressing different mouse-button combinations
Feature showcase:
ASUS on its new mouse:
Reaction time is everything in competitive games, so we designed the Keris II Ace in consultation with esports professionals to make sure we dialed in every feature exactly right. That all starts with the weight: despite being a wireless gaming mouse, we’ve dropped 25 grams off the previous design, allowing it to slide effortlessly across your mousemat. The chassis features an ergonomic design made from environmentally friendly nylon derived from renewable castor oil, available in classic black or a stunning Moonlight White colorway. The Keris II Ace even comes with anti-slip grip tape if you need a little extra friction to keep the perfect grip.
The Keris II Ace features an all-new ROG AimPoint Pro optical sensor, with a 42,000 DPI and incredibly low deviation of less than 1% for incredible in-game precision. It’s so accurate that it can even track on glass (though we don’t recommend trying that at your next esports tournament appearance). It also comes with a new Polling Rate Booster, which increases the Keris II Ace’s polling rate to 4K in wireless mode and 8K in wired mode.
ROG Optical Switches bring crisp and instant actuation with a 100-million-click lifespan, letting you ping the objective as many times as it takes to get your team’s attention. We also outfitted the Keris II Ace with tri-mode connectivity, letting you connect via wired USB, Bluetooth, or our ultra-low latency 2.4GHz wireless with ROG SpeedNova technology. That last option uses our cutting-edge ROG Omni Receiver tech, which can connect both the ROG Keris II Ace and a supported keyboard with a single dongle, keeping your desktop clean and clear and freeing up a USB port on your PC.
