PowerColor Unveils Hellhound RX 7800 XT Sakura Edition with White Shroud, Pink Fans, and Custom GPU Holder
Image: PowerColor
PowerColor has introduced the Hellhound RX 7800 XT Sakura Edition, a new version of its custom RDNA 3 GPU that is said to offer a fresh aesthetic twist to the graphics card world. Two versions of the Sakura Edition will be available, including a Limited Edition that not only features unique packaging, but also a custom GPU holder with matching theme.
Model links:
A look at their packaging:
Specifications include:
Video Memory16GB GDDR6
Stream Processor3840 Units
Game Clock2213MHz
Boost Clock2520MHz
Memory Speed19.5 Gbps
Memory Interface256-bit
Bus StandardPCIE 4.0
Display Connectors1 x HDMI 2.1, 3 x DisplayPort 2.1
Form FactorATX
Cooler2.5 Slot Triple Fan
Power ConnectorTwo 8-pin PCI Express Power Connector
Crossfire SupportYes ( support DirectX12/Vulkan)
OpenGL4.6
DirectX Support12
Minimum System Power Requirement (W)750W
Card Dimension(mm)322mm*134mm*50mm / 332*147*50mm(w/bracket)
PowerColor on its new GPUs:
The market has seen its share of themed graphics cards, but the Hellhound RX 7800 XT Sakura Edition stands apart with its all-white design accented by subtle pink details. This design choice not only maintains the card’s sleek and unified appearance but also introduces a touch of grace, reminiscent of cherry blossoms. PowerColor’s dedication to this theme is evident in every aspect of the card, from an all white PCB to the uniquely white heatsink and cooler design with adorned with pink accents.
This card boasts advanced cooling and rapid clock speeds for demanding games. Its LED lighting on the fans offers three modes: vibrant Pink Blossom, sleek Pure White, and an Off setting for a distraction-free experience. With a dual BIOS switch, gamers can optimize for Overclocking or Silent operation, tailoring the card to any gaming environment.
The Hellhound series is celebrated for its exceptional cooling capabilities and quiet operation, a testament to PowerColor’s engineering. The Sakura Edition embodies this spirit of excellence, blending raw power with the elegant design of the Sakura theme. Gamers can expect to immerse themselves in their play, backed by a card that not only excels in performance but also adds a unique aesthetic flair to their setup.
PowerColor on the limited edition:
For limited quantity, Hellhound RX 7800 XT Sakura Limited Edition will be available. This version elevates the Sakura theme with unique packaging that captures the essence of its inspiration. Each card comes with a custom GPU holder support, ensuring your setup not only looks exceptional but is also secure, making this limited edition a must-have for enthusiasts looking to celebrate the fusion of high-end gaming performance with unparalleled beauty.
Image: PowerColor
