Akasa has launched the ALUCIA H4A, a low-profile CPU cooler for AMD platforms (i.e., AM4 and AM5) that features a height of just 29.5 mm, complemented by a four-copper heatpipe cooler with nickel-plated copper base and 92 mm photic blue edition fan. Featuring advanced blade technology and intelligent PWM speed control, the fan is geared toward AMD systems and CPUs with a maximum TDP of 95 watts.
General info:
- Socket Type: AMD AM4, AM5
- Suggestion TDP (W): 95
- Cooler Dimension: 94 x 94 x 29.5 mm
- Heatsink Material: Aluminium fins with four copper heatpipes
- Installation: Mounting screw
- Weight: 232 g
Fan specs:
- Dimension: 92 x 92 x 12 mm
- Bearing: Ball Bearing
- Fan Speed: 800 – 3600 RPM
- Max Airflow: 40 CFM
- Max Air Pressure: 2.2 mm-H2O
- Noise Level: 17 – 35.8 dB(A)
- Current Rating for Fan: 0.28A
- Voltage Rating for Fan: DC 12V
- Fan Connector: 4-pin PWM
- Fan Life Expectancy: 40,000 hours
- Warranty : 2 years
A closer look at its height:
Akasa on its cooling performance:
4 high-performing copper heat pipes enable efficient heat dissipation. While the superior rotor design with Ball bearing improves lubrication, reduces fan noise, and extends fan life up to 40,000 hours. Ensuring the cooler can support CPUs up to 95W thermal design, assisted by the highly efficient nickel-plated copper base.
