Palit has announced the release of the GeForce RTX 4070 White and GeForce RTX 4060 Ti White, two new gaming graphics cards based on NVIDIA’s Ada architecture that are said to offer a perfect blend of elegant looks and uncompromised power, featuring a sleek white color scheme across the shroud and backplate for enthusiasts working with, or leaning toward, a light-colored PC build. The former runs up to 1.7x faster with DLSS 3 versus the GeForce RTX 3070 Ti while consuming 23% less power, Palit noted, while the GeForce RTX 4060 Ti White offers a 20% performance boost over the GeForce RTX 3060 Ti while consuming 20% less power.
Product listings:
Key specifications for these GPUs include:
- Palilt GeForce RTX 4070 White
- Memory Amount: 12GB
- Memory Interface: 192bit
- DRAM Type: GDDR6X
- Graphics Clock: 1920 MHz
- Boost Clock: 2475 MHz
- Memory Clock: 21 Gbps
- CUDA Cores: 5888
- Memory Bandwidth (GB/sec): 504
- HDMI: HDMI 2.1a
- DisplayPort: DP1.4a x 3
- Height: 2 Slot
- Board Size: 269.1 x 127 x 40.1 mm
- Graphics Card Power: 200W
- Recommended System Power: 750W
- Supplementary Power Connectors: 8-pin x 1
- Palit GeForce RTX 4060 Ti White 8GB
- Memory Amount: 8GB
- Memory Interface: 128bit
- DRAM Type: GDDR6
- Graphics Clock: 2310 MHz
- Boost Clock: 2535 MHz
- Memory Clock: 18 Gbps
- CUDA Cores: 4352
- Memory Bandwidth (GB/sec): 288
- HDMI: HDMI 2.1a
- Height: 2 Slot
- Graphics Card Power: 165W
- Recommended System Power: 650W
Some box shots that show off their similar design:
Palit on its new GPUs:
The twin 95mm fans and optimized backplate vents ensure effective thermal performance. Equipped with 0dB technology, the cards minimalize the noise during light loads like multimedia applications and browsing. During demanding tasks, fans automatically adjust to optimal cooling and performance.
The Palit GeForce RTX 4070 and RTX 4060 Ti White Series cater to both gamers and creators. Gamers will benefit from the exceptional performance boost, allowing them to experience high frame rates and smooth gameplay. Creators will appreciate the powerful processing capabilities for tasks like video editing and high-resolution design work. Additionally, the sleek white aesthetics perfectly complement a modern creative workspace.
