EK has unveiled the EK-Quantum Momentum² Quad RAM Module Set D-RGB, a new advanced water-cooling solution that includes a water block capable of covering four RAM sticks with aluminum heatsinks, complemented by dynamic RGB lighting. This product is compatible with both single and double-sided DDR4 and DDR5 memory modules, EK confirmed, while compatibility with the company’s EK-Matrix7 standard has also been noted.
Product link and availability:
- EK-Quantum Momentum² Quad RAM Module Set D-RGB ($179.99)
- Available for purchase now via the EK Webshop or EK Partner Reseller Network
Compatibility:
- DDR4 and DDR5
- RAM slot spacing: 8,88mm and 9,14mm
Technical Specification:
- RAM Module Dimensions: 139 x 36,6 x 8,25mm
- Color: Black
- Heatsink Material: Aluminum
- Water Block Dimensions: 139x42x14,3mm
- Water Block Cold Plate Material: nickel-plated copper
- Top: plexi and acetal stand-out
- D-RGB LED Count: 14
Enclosed:
- EK-Quantum Momentum² Quad RAM Module water block
- Four (4) aluminum heatsinks
- Thermal pads
- Mounting screws
- Allen key
EK on its latest cooling solution:
The EK-Quantum Momentum² Quad RAM Module Set D-RGB accommodates both single and double-sided DDR4 and DDR5 memory modules, ensuring versatility across different RAM configurations. It features four sleek, black, anodized aluminum heatsinks with an elox finish for enhanced durability and corrosion resistance. This treatment not only improves the heatsinks’ appearance but also boosts their thermal conductivity and cooling effectiveness.
Mounted over these heatsinks is the water block, featuring a nickel-plated copper cold plate and a transparent plexi top with the signature EK Quantum design element, an acetal stand-out piece. Additionally, it is equipped with two G1/4 ports to ensure versatile system integration. This setup not only enhances cooling efficiency but also showcases the premium quality and visual aesthetics that are hallmarks of the EK Quantum series.
The aesthetics of the EK-Quantum Momentum² Quad RAM Module Set D-RGB are elevated by 14 individually addressable D-RGB LEDs. These LEDs provide uniform and striking illumination across the water block, allowing for a wide range of color customization and lighting effects. The individually addressable RGB LED is compatible with popular RGB sync technologies from all major motherboard manufacturers, enabling seamless integration and synchronization with your system’s overall theme, bringing a vibrant and dynamic flair to your memory modules.
The EK-Quantum Momentum² Quad RAM Module Set D-RGB aligns with the EK-Matrix7 standard, embodying a modular design approach that ensures a 7mm increment in product and port dimensions for easier tube routing and a streamlined look in custom loop liquid cooling systems. This standard not only simplifies the installation process but also enhances the aesthetic and functional harmony within the system, ensuring a perfect fit with other EK-Quantum components.
