Noctua HOME Product Line Offers Cooling Solutions for Home, Office, and Multi-purpose Ventilation
Image: Noctua
The Noctua HOME product line comprises two fan sets and nine accessories for use around the home and office. Having established itself as the go-to cooling fan manufacturer for PC enthusiasts seeking high-performance and low-noise solutions with PC applications Noctua has expanded its technology beyond the PC realm. The Noctua HOME product line is designed to aid in cooling a wide range of electronic devices as well as directing focused airflow in specific areas of a room.
“Noctua originates from the PC cooling market, but our fans’ award-winning performance, quietness of operation and long-term stability are just as useful in various other applications”
“Our industrial clients as well as tech-savvy DIYers have already been using our fans for applications beyond the PC cooling space for many years, so the new HOME line marks the next step in leveraging our technologies for a wider scope of cooling demands and making them more accessible for a broader audience.”
Roland Mossig (Noctua CEO)
NV-FS1 Kit
The NV-FS1 set includes a pivoting 120 mm/140 mm fan mount that can be installed on flat surfaces or mounted to a wall. It comes with an NF-A12x25 fan, an airflow amplifier (shroud) to focus airflow, a controller, and a 12V DC power supply with a barrel connector. The kit also includes a fan grill, cable ties, extension cable, integrated magnets, and mounting screws. Most parts can be purchased separately.
NV-FS2 Kit
The NV-FS2 set is aimed at electronic applications where OEM cooling may not be sufficient enough. It features many of the same components of the NV-FS1 set but swaps out the pivoting mount for multipurpose gaskets and pads allowing fans to be mounted on, or under, devices such as A/V receivers or stereo equipment, video game consoles, set-top boxes, routers or switches, and more. NOCTUA adds they could also be used to improve the cooling efficiency of radiators. As with the NV-FS1 set, most parts can be purchased separately.
NV-FH2 Fan Hub
The NV-FH2 fan hub is a modified version of Noctua’s NA-FH1 SATA-powered 8-fan hub. It has been redesigned with a 12V barrel port that can be used with its new power supply in the above kits (also available separately) and features a removable cover. NV-FH2 fan hub allows the Noctua HOME product line to expand with a wider range of configurations while consolidating power needs to a central hub.
Press Release (via official page):
“The launch lineup of Noctua’s HOME line comprises two complete, ready-to-use fan sets as well as nine modular accessory products, all of which make it possible to employ Noctua fans for typical home, office or multi-purpose ventilation tasks. For example, the NV-FM1 is a highly versatile, pivoting mount for 120 and 140mm fans that cannot only be used as a simple stand on desks or other level surfaces, but can also be fixed to walls, ceilings, furniture, or other objects. For applications that require a strong, focused beam of airflow, it can be paired with the tailored NV-AA1-12 airflow amplifier that significantly enhances the fan’s ventilation performance. Both products are bundled in the NV-FS1 set with the award-winning NF-A12x25 fan, an NA-FC1 fan controller as well as the new NV-PS1 230/115V AC to 12V DC power supply plus a fan grill and extension cable. In sum, the NV-FS1 is a sturdy, premium grade quiet desk or room fan that can be installed just about anywhere using screws, zip-ties or the integrated magnets.
The NV-MPG1 multi-purpose gaskets are ideal for placing a cooling fan on top of A/V receivers, DVRs, video game consoles, stereo equipment, routers, switches, set-top-boxes or other devices that have ventilation holes on top. By contrast, the NV-MPP1 multi-purpose pads have been conceived for placing fans underneath devices that have ventilation holes at the bottom side. The NV-FS2 set combines the gasket and the pads with an NF-A12x25 fan, NA-FC1 controller, NV-PS1 power supply, NA-FC1 fan controller, fan grill and extension cable, which makes for a highly adaptable cooling package that can be used for various device cooling applications, but also as a simple desk fan or for enhancing the efficiency of heating radiators.
Last but not least, the NV-FH2 is an even more robust version of the popular NA-FH1 8-way fan hub, tailored for home, office and multi-purpose ventilation applications. As such, it trades the NA-FH1’s S-ATA power input for a 12V barrel connector and features a removable cover for mechanical protection and a clean appearance. The NV-SPH1 set combines the NV-FH2 with the new NV-PS1 power supply, giving customers a complete, safe and certified solution for powering up to 8 fans from the mains.
Combined with Noctua’s existing ecosystem of 40, 60, 80, 92, 120, 140 and 200mm fans (24V, 12V, 5V with USB power adaptor cables) as well as various accessory products such as fan grills and extension or splitter cables, the new HOME line products give customers a trusted, modular and highly flexible toolbox for solving typical cooling challenges in their homes, offices and various other environments.
Links
NV-FS1 desk, room and multi-purpose fan set
NV-FS2 multi-purpose device cooling fan set
NV-FM1 pivoting fan mount
NV-PS1 115/230V AC to 12V DC power supply
NV-FH2 8-port fan hub
NV-SPH1 powered fan hub set
NV-MPG1.brown multi-purpose gasket
NV-MPG1.black multi-purpose gasket
NV-MPP1.brown Sx4 multi-purpose pads
NV-MPP1.black Sx4 multi-purpose pads
Suggested retail prices
The manufacturer’s suggested retail prices are as follows:
NV-FS1: EUR/USD 99.90
NV-FS2: EUR/USD 79.90
NV-FM1: EUR/USD 39.90
NV-AA1-12: EUR/USD 14.90
NV-PS1: EUR/USD 29.90
NV-FH2: EUR 49.90 / USD 44.90
NV-SPH1: EUR 69.90 / USD 59.90
NV-MPG1.brown: EUR/USD 14.90
NV-MPG1.black: EUR/USD 14.90
NV-MPP1.brown Sx4: EUR/USD 12.90
NV-MPP1.black Sx4: EUR/USD 12.90
Availability
All new HOME line products are available as of today via Noctua’s official Amazon stores:
Buy NV-FS1
Buy NV-FS2
Buy NV-FM1
Buy NV-AA1-12
Buy NV-PS1
Buy NV-FH2
Buy NV-SPH1
Buy NV-MPG1.brown
Buy NV-MPG1.black
Buy NV-MPP1.brown Sx4
Buy NV-MPP1.black Sx4
