Lian Li has partnered with DAN Cases to produce the A3-mATX, a new PC case for M-ATX and ITX motherboards that features side and top panels with steel mesh. Coming in both black and white color options, the new case is available now for $69.99 MSRP at retailers that include Newegg. Caseking, and Overclockers UK.
Product and purchase links:
- M-ATX case collaboration with Daniel Hansen from DAN Cases and LIAN LI
- High-performance mesh panels at the top and both sides
- ATX / SFX PSU mounting bracket adjustable with 5 different heights on both the front and right side
- Supports 4.5 slots GPUs up to 415mm in length, AIOs up to 360mm, and up to 10 x 120mm fans
- Glass side panel and vertical GPU mounting are available as additional accessories
- Available in black and white at MSRP $69.99
Specifications:
| Model | A3-mATX |
| Case Type | MicroATX Chassis |
| Dimensions | (D) 443 x (W) 194 x (H) 321.5 mm |
| Color | Black / White |
| Material | Steel |
| Motherboard Support | M-ATX / MINI-ITX |
| Expansion Slot | 4 |
| Storage | Tray: 2 x 2.5” SSD Bottom: 1 x 2.5” SSD / 1 x 3.5” HDD |
| GPU Length Clearance | 415mm (Max.) |
| CPU Cooler Height Clearance | 165mm (Max.) |
| PSU | ATX / SFX / SFX-L (Max. 220mm) |
| Fan Support | (Top) 3 x 120mm / 2 x 140mm (Side) 3 x 120mm / 2 x 140mm (Bottom) 3 x 120mm / 2 x 140mm (Rear) 1 x 120 mm |
| Radiator Support | (Top) 360 / 280 / 240 (Side) 360 / 280 / 240 (Bottom) 280 / 240 |
| I/O PORTS | 1 x Power Button 2 x USB 3.0 1 x USB type C 1 x Audio 1 x Microphone |
| Dust Filters | 1 x Bottom |
Lian Li on its new case:
Featuring high-performance mesh panels at the top and both sides, the A3-mATX ensures optimal airflow and cooling for your compact system. The PSU mounting bracket that supports ATX and SFX power supplies is adjustable at 5 different heights, creating different clearance scenarios that allow this micro-ATX chassis to house larger components, enhancing flexibility. The case supports a wide range of hardware, including 4.5 slots GPUs up to 415mm in length, up to 360mm AIOs, and up to 10 x 120mm fans in total. A glass side panel and vertical GPU mounting kit are available as optional accessories, providing users with great levels of aesthetic customization.
Even with its micro-ATX footprint, the A3-mATX does not slack on what components it can fit. The possibility of accommodating 4.5 slots GPUs up to 415mm in length promises the option of going for high-end GPUs. AIOs up to 360mm can be installed on both the top and the left side for sufficient cooling, and the maximum capacity of 10 x 120mm fans for rigorous gaming sessions.
The PSU mounting bracket of the A3-mATX offers unparalleled versatility with its multiple mounting locations. Both the front and the right side of the case can house the PSU in five different height settings. Compatible PSU sizes include ATX, SFX, and SFX-L with a maximum length of 220mm. The hard drive mounting tray is also highly versatile with a total of 4 different settings on the front and the right side. Depending on the different configurations of the PSU, the compatibility of the GPU, radiator, and cooling fans changes accordingly, allowing users to express true freedom when building.
The A3-mATX even with the volume being just over 26L, boasts 3 high-performance mesh panels on the top and both sides of the case, providing ample airflow for this compact chassis. The top panel is secured by 2 easy to remove thumb screws, while the side panels can be quickly removed with their toolless mounting mechanism. The reinforced plastic front panel goes for a modern, minimalist look, also detachable thanks to toolless mounting. A magnetic dust filter is provided at the bottom of the case, covering the entire bottom opening to keep your build nice and tidy.
Two additional accessories are available for the A3-mATX, starting with a tempered glass left-side panel to provide users with an unrestricted view of their PC build, and a vertical GPU kit that allows users to opt for direct air intake for their graphics card from the left-side panel. Both accessories are available in black and in white, at an MSRP of $12.99 and $49.99 respectively.
