COUGAR Introduces FV270 Mid-Tower Case with Tempered Curved Glass Panels
Image: COUGAR
COUGAR has shared the pricing and availability details for the FV270, a new mid-tower PC case that features tempered curved glass panels, enabling what the company says is an unrivaled panoramic view of the hardware inside. Available in black or white color options, this case supports E-ATX motherboards and includes room for GPUs measuring up to 420 mm in length.
Product links and pricing:
  • FV270 (White, Black)
  • USA: Black $179.99, White $179.99 – available now (Amazon, Newegg)
  • UK: Black £159, White £169 – available in July
  • Europe: Black €189, White €199 – available in Q3
Key features include:
  • Tempered, curved glass panoramic perimeter amplifies transparency and brilliance for an epic view.
  • Angled cooling fan placements focus airflow in uninterrupted, continuous streams.
  • Additional air intake accessed by lifted front
  • Reverse cable management eliminates clutter
  • Compatible with bleeding-edge E-ATX motherboards and accommodates 420mm GPUs, with rotatable brackets for horizontal/vertical orientation options.
  • Strategically positioned and easily removable filters guard against dust.
  • Easily detachable top and bottom brackets streamlines setup.
Specifications:
Product NameFV270 / FV270 (White)
Case Form FactorMid Tower
Motherboard TypeMini ITX / Micro ATX / ATX / CEB / E-ATX
Dimensions (WxHxD)268 x 530 x 512 (mm)
10.6 x 20.9 x 20.2 (in)
I/O PanelType C Gen 2 x 1, USB 3.0 x 2, 4 Pole Headset Audio Jack, Reset Button
3.5″ Drive Bay2
2.5″ Drive Bay2+2 (converted from 3.5″ drive bays)
Expansion Slots7 (horizontal slots can be converted into vertical slots)
Vertical GPU SupportYes
Cooling Fan SupportTop120mm x 3 / 140mm x 2
M/B Side120mm x 2 / 140mm x 2
PSU Shroud120mm x 2 / 140mm x 2
Bottom120mm x 1
Rear120mm x 1 / 140mm x 1
Pre-installed FansBottom120mm Reversed ARGB PWM fan x 1
Speed500-1200 ± 10%
Connector5V 3 Pin (ARGB) / 4 Pin (Fan)
Maximum Number of Fans9
Water Cooling SupportTop360mm / 280mm / 240mm / 140mm / 120mm
M/B Side280mm / 240mm / 140mm / 120mm
PSU Shroud240mm / 120mm
Bottom
Rear140mm / 120mm
RGB Sync with M/BYes
Max. Graphics Card LengthHorizontal420 (mm) / 16.5 (in) (Only fans at the M/B Side)
330 (mm) / 13 (in) (Radiator with fans at the M/B Side)
Vertical450 (mm) / 17.7 (in)
Max. CPU Cooler Height180 (mm) / 7.1 (in)
Max. PSU Length250 (mm) / 9.8 (in)
A product gallery:
COUGAR on its latest case:
Transparency and brilliance are at the core of the FV270’s design. The polyhedral, tempered curved glass perimeter eliminates obstructive edges for an unparalleled view of the interior.
Synthesizing bold aesthetics with functionality, the FV270 also establishes a new benchmark in airflow management: innovative angled cooling fan placements ensure focused airflow dynamics, and a lifted front accesses additional ventilation, bringing in cold current from below.
Cable management is seamless in the FV270, with reverse routing that keeps clutter hidden behind the motherboard. This feature, complemented by a solid side panel, ensures a sleek, clean exterior allowing your components to shine…literally.
The FV270 supports cutting-edge E-ATX motherboards and accommodates GPUs up to 420mm, with versatile brackets for horizontal or vertical mounting. This wide compatibility future-proofs builds and provides limitless possibilities for customization.
Protection from dust is thorough, with strategically placed and easily removable filters that safeguard your components. This filtration system extends the life of your hardware, reducing maintenance and preserving your PC’s pristine condition.
An optional rotating mounting platform, illuminated from below, displays your collectibles and transforms your PC into a personal statement.
Combining transparency, functionality, and unorthodox design, the FV270 lets the world look through its glass brightly, to see your build not only as it is, but all that you imagine it to be.
