GIGABYTE Lists AORUS FO27Q2 QD-OLED Gaming Monitor with 240 Hz Refresh Rate
Image: GIGABYTE
GIGABYTE is expanding its lineup of OLED gaming monitors with the AORUS FO27Q2, a new QHD display that appears to have a lot in common with the previously outed FO27Q3, including a 26.5-inch QD-OLED display by Samsung, but with at least one obvious difference in the form of a 240 Hz (vs. 360 Hz) refresh rate. This monitor features a three-year warranty, which GIGABYTE says includes coverage for panel burn-in.
Display specs include:
  • Panel size and type: 27″ QD-OLED
  • Display surface: Anti-reflection
  • Resolution: 2560 x 1440 (QHD)
  • Refresh rate: 240 Hz
  • Response time: 0.03 ms GTG
  • Color saturation: 99% DCI-P3
  • HDR: VESA DisplayHDR True Black 400
  • VESA Certified ClearmR: ClearMR 13000
Connectivity comprises:
  • 2 x HDMI 2.1
  • 1 x Displayport 1.4
  • 1 x USB Type-C (Alternate Mode; Upstream port; Power Delivery up to 18W)
  • 2 x USB 3.2 Downstream ports
  • 1 x USB 3.2 Upstream port
  • 1 x Earphone Jack
  • 1 x Microphone Jack
An explainer on GIGABYTE’s OLED Care, which features an AI-based algorithm to minimize the risks of burn-in issues:
GIGABYTE on its new monitor:
Featuring a 27-inch 1440p QD-OLED panel with a remarkable 240Hz refresh rate and 0.03 ms gray-to-gray (GTG) response time, the FO27Q2 stands as one of the fastest and most responsive OLED gaming monitors available. Boasting exclusive Tactical Features and AI-based OLED Care, it’s designed for those who demand the best and refuse to settle.
