Samsung 990 PRO with Heatsink 1TB PCIe Gen4 M.2 NVMe SSD Review
Test Setup
Please read our SSD Storage Review Format and Methodology article for an explanation of our test system, how we test, procedures, and goals for SSD reviews. Note that the test system has been changed and updated as of this review, and moving forward, please refer to the System Setup table below for the details and specs on the new test system. All of the SSDs in this review have been re-tested on this new system setup, and all the SSD data in this review is fresh for this review.
Samsung 990 PRO with Heatsink 1TB PCIe Gen4 M.2 NVMe SSD System Setup Table
We are using the motherboard’s current default BIOS settings.  We are running the latest motherboard BIOS.  We have Windows 11 Pro configured to run in the “Balanced” power profile.  Windows has the latest updates.  We are running the latest Win11 23H2 update from October 2023.
CrystalDiskInfo
Installation of the SSD went smoothly. Upon installation we discovered that the firmware was out of date, there was a newer version as Samsung Magician Software told us. The firmware version on our SSD when installed was 3B2QJXD7. When we ran Samsung Magician Software to update the firmware, it updated it to 4B2QJXD7. This is the version we used while testing.
In CrystalDiskInfo we can see information on the SSD below. We can see that the Samsung 990 PRO is running at PCIe 4.0 x4 and NVMe 2.0 and supports S.M.A.R.T., TRIM, and VolatileWriteCache.
Samsung 990 PRO with Heatsink 1TB PCIe Gen4 M.2 NVMe SSD CrystalDiskInfo Screenshot
Performance
Cooling
Price Value
The Samsung 990 PRO with Heatsink 1TB PCIe Gen4 M.2 NVMe SSD is a very high performing Gen4 SSD, with incredible write performance whether sequential or random, it holds some of the highest Gen4 generation SSD performance among the competition. It also works well for gamers, content creators and has excellent workstation application performance for professionals. The temperatures can run warm under constant use, so use good cooling, otherwise you do pay a premium for this Samsung SSD among others, it is loaded with features and the best SSD toolkit software in the business.
