The Hyte THICC Q80 Trio is being shown off at Computex and marketed as “The Highest Performing Cooler Ever Made”. While many 360 mm and even 240 mm AIOs will suffice for a wide range of CPU cooling applications, sometimes you need the biggest hammer you can find to get the job done and the Hyte THICC Q80 Trio looks like it might just fit the bill. Thicker radiator AIOs are becoming more widely available and although some don’t always manage to check all the cooling performance boxes compared to their thinner counterparts, Hyte’s new offering could be exactly what an overclocker or someone with an exceptionally powerful CPU may be looking for.
The Hyte THICC Q80 Trio features a 52mm thick radiator (heat exchanger) paired with dual pumps and a copper plate with 50% more skived fin coverage than the previous generation. Three fans inside a single enclosure provide up to 105.8 CFMs with an H20 static pressure of 8.14 mm. A 5-inch IPS 60Hz display is mounted to the block via a 180° adjustable swivel. Hyte has said that the THICC Q80 Trio will be available in Panda (B+W) and Pitch Black designs.
Per Computex Product Announcement:
“Introducing THICC Q80 Trio – the most THICC, cool, quiet, and intelligent AIO for your CPU. A 360mm long, 52mm THICC Ginormous Heat Exchanger absorbs more watts than any other liquid cooler, while the class-leading Dual Harmonic Pumps effortlessly chill the hottest CPUs. Our bigger 2nd gen copper cold plate with a 50% higher skived fin coverage and upgraded liquid flow path drops temps by up to 2°C more. THICC FP12 Trio has a refreshed omnidirectional aesthetic, integrating fans into a single frame while silently obliterating heat with the highest performance-to-noise ratio on the market. Powered by Nexus Link, THICC Q80 Trio can control an entire system’s worth of cooling and lighting off a single cable with up to 18 devices on a single port or up to 36 devices across both Type-C and Type-M channels. It also comes in a new Pitch Black colorway!”
Features (per announcement):
- The Raid Boss of Liquid Coolers – Engineered for complete thermal domination with a Ginormous 360mm x 52mm THICC Heat Exchanger, class-leading Dual Harmonic Pumps, and THICC FP12 Trio, delivering the highest performance-to-noise ratio on the market.
- THICC FP12 Trio – New omnidirectional aesthetic integrates fans into a single frame, refreshing the look while delivering the same 32mm THICC performance that silently obliterates heat with monstrous 105.8 CFM airflow and 8.14 mm-H2O static pressure.
- Way More Copper – Exceedingly huge 2nd generation copper cold plate with 50% higher skived fin coverage and upgraded liquid flow path drops temps by up to 1°C per 100W.
- Supersized Screen – HD 60Hz 5” Ultraslim IPS Display with a 42-Pixel qRGB Array on a Double-Hinged Floating Spout with 180 degrees of adjustable swivel.
- Powered by Nexus Link – Control an entire system’s worth of cooling and lighting with 1x Nexus Link Type-C and 1x Nexus Link Type-M channels, capable of powering up to 18 devices on a single cable, or up to 36 devices across both channels.
- New Liveries for 2024 – Available in both Panda and Pitch Black colorways, giving you more options to match the aesthetics of your setup.
