ASUS Unveils 27″ 5K PA27JCV (IPS) and 31.5″ 4K PA32UCDM (QD-OLED) ProArt Displays
Image: ASUS
ASUS is expanding its lineup of ProArt gear for professional users today with the PA27JCV and PA32UCDM, two new monitors that feature a 27-inch 5K IPS panel and 31.5-inch 4K QD-OLED panel, respectively. The ProArt Display OLED PA32UCDM, which boasts support for various HDR metadata formats and hardware calibration tools for leading color accuracy, supports refresh rates of up to 240 Hz, ASUS confirmed.
ProArt Display 5K PA27JCV features include:
  • 5K (5120×2880) resolution IPS panel with wide viewing angles
  • 2.5x the PPI versus a 27-inch FHD display
  • Calibrated in the factory, Calman Verified to achieve an average ΔE value of less than 2 for accurate colors
  • 99% coverage of DCI-P3 color gamut
  • 100% coverage of RGB color gamut
  • AGLR coating offers a paper-like screen effect, minimizing reflections
  • Tilt, swivel, pivot, and height adjustments
  • Ambient Light Sensor synchronizes display brightness and color temperature
  • Backlight sensor allows the display to bypass warm-up time
  • DisplayPort and HDMI ports
  • USB Type-C port with 96W Power Delivery
  • Auto KVM for easily controlling two two connected using just one keyboard and mouse
A look at the PA27JCV:
Image: ASUS
ProArt Display OLED PA32UCDM features include:
  • 31.5-inch monitor with 4K resolution
  • 240 Hz refresh rate
  • 1000 nits of peak brightness
  • True 10-bit color depth
  • 99% coverage of the DCI-P3 color gamut
  • Average ΔE value of less than one 1 for color accuracy
  • Supports multiple HDR metadata formats, including HLG and HDR10
  • ASUS ProArt Hardware Calibration tech for color-accuracy optimization and color profile write-back
  • configured to work seamlessly with Calman and Light Illusion ColourSpace CMS professional hardware calibration software
  • Thunderbolt 4 port with 96W Power Delivery
  • HDMI 2.1 port, built-in USB Hub
  • Included bracket for mounting the display on a partition wall
A look at the PA32UCDM:
Image: ASUS
ASUS noted for the PA27JCV:
…the ProArt Display PA27JCV features many of our latest efforts to elevate the sustainability of our products. It ships in FSC Mix-certified paper packaging, and we’re targeting the requirements of key environmental efficiency standards.
