NETGEAR Expands WiFi 7 Portfolio with Nighthawk RS300 Router and Orbi 770 Series Mesh System
Image: NETGEAR
NETGEAR has expanded its WiFi 7 mesh and standalone router lines with the Orbi 770 Tri-band Mesh System and Nighthawk RS300 Router, two new products that are said to be the company’s most affordable WiFi 7 products to date, building on its promise to provide powerful WiFi performance and secure connectivity. The Orbi is available for pre-order now, while the Nighthawk is available for purchase immediately through NETGEAR.com and will arrive at major retailers subsequently.
Product links:
Pricing and availability:
  • RBE773: Router and 2 Satellites – 3 pack, $999.99 MSRP
  • RBE772: Router and 1 Satellite – 2 pack, $699.99 MSRP
  • RBE770: Add-on Satellite, $399.99 MSRP
  • RS300: Router – $329.99 MSRP
Orbi 770 Technical Specifications:
  • Ultra-Fast WiFi 7 Tri-Band Speeds up to 11Gbps – Experience combined Multi-Gigabit speeds up to 11Gbps with 2.4GHz, 5GHz, and 6GHz bands.
  • Higher Capacity & Robust WiFi – Supports WiFi 7 technology enhancements like 320 MHz, 4K QAM and preamble puncturing.
  • Multi-link Operation – Combines two WiFi bands at once, for both backhaul (shared 5GHz & 6GHz) and fronthaul (5GHz & 6 GHz) to improve network reliability, reduce latency, and ensure data is delivered with maximum speed.
  • Multi-Gig Speeds with 2.5 Gig Internet Port – Use the 2.5 Gig internet port for multi-gig cable and fiber plans. Compatible with any internet service provider.
  • More Multi-gig Wired ports on Router and Satellites – Plug in wired devices to improve performance or setup a multi-gig wired connection between the router and satellites via three 2.5Gbps Ethernet ports on the router, and two 2.5Gbps Ethernet ports on the satellites.
  • Do It All with the Orbi App –Easily manage your network from anywhere, including pausing the Internet, running Internet speed tests, tracking your Internet data usage, setting up separate guest networks, and more.
Nighthawk RS300 Technical Specifications:
  • Blazing-Fast WiFi 7 Tri-Band Speeds up to 9.3Gbps – Experience combined Multi-Gigabit speeds up to 9.3Gbps with the ultra-fast 6GHz WiFi band for smoother WiFi experiences and less interference from neighboring networks.
  • 4x Faster Speeds – WiFi 7 delivers 2.4x faster speeds than WiFi 6 with ultra-wide 320MHz high-capacity channels and 4K QAM to maximize performance across your connected devices.
  • Multi-Gig Speeds with 2.5Gig Internet Port – Use the 2.5Gbps internet port for today’s faster cable and fiber plans. Or link one LAN port and the internet port together for speeds up to 2Gbps for a modem that does not have a multi-gig port but supports link aggregation. Compatible with any internet service provider.
  • Improved Performance with 2.5Gig Wired Ports – Enjoy improved performance on your gaming and entertainment devices by plugging them into the two 2.5Gbps ports for faster wired connections. And link the two 1Gbps LAN ports together for speeds up to 2Gbps for a NAS device.
  • Easy file sharing – Plug a thumb drive to the router’s USB port to easily share files.
  • Do It All with the Nighthawk App – Configure your WiFi for peak performance on priority devices. Easily manage your network from anywhere, including pausing the Internet, running Internet speed tests, tracking your Internet data usage, setting up separate guest networks, and more.
A look at the Orbi 700:
Image: NETGEAR
NETGEAR on the latest generation of WiFi:
WiFi 7 unlocks 2.4 times faster speeds than WiFi 6, delivers low latency and better handles WiFi interference for families to seamlessly enjoy next gen 4K/8K streaming, video conferencing, gaming, and more. Since the launch of NETGEAR’s first WiFi 7 offerings – Nighthawk RS700 and Orbi 970 – multi-gig internet speeds have become more affordable, work from home demands have remained steady, and more devices such as AR/VR headsets or AI-focused platforms like CoPilot+ have been introduced that require extreme low latency and higher throughput.
