Corsair’s New LX RGB Fans Combine Brilliant Lighting with Exceptional Cooling
Image: Corsair
Corsair is launching the LX RGB Series today, a new lineup of cooling fans under the iCUE LINK ecosystem that are said to combine amazing lighting with high-performance cooling, featuring 120 mm or 140 mm fans, each with 18 individually addressable RGB LEDs. The new fans, which are PWM-controlled and run up to 2,400 RPM, feature a Zero RPM mode for silent running at low loads.
Product links:
  • iCUE LINK LX120 RGB 120mm PWM Single Fan Expansion (Black)
  • iCUE LINK LX120 RGB 120mm PWM Single Fan Expansion (White)
Key features:
  • 18 RGB LEDs per fan spread across dual light loops
  • iCUE LINK System Hub included
  • AirGuide technology for concentrated cooling
  • Magnetic Dome bearing for minimal noise
A promo video:
A comparison of iCUE Link Fans:
Image: Corsair
Corsair on its latest fans, including the QuickTurn screw system:
Available in 120mm and 140mm sizes, in your choice of black or white to match the aesthetic of your build, each LX RGB fan features 18 individually addressable RGB LEDs spread across an inner and outer light loop, creating spectacular, fully customizable lighting effects – including the iCUE LINK-exclusive Time Warp mode that creates mesmerizing optical illusions. All of this is made possible by the new and improved iCUE 5 software, making it easier than ever before to customize and switch between lighting effects or synchronize them with your games.
These great looks are backed up by rigorous engineering and meticulous testing to deliver strong, efficient cooling to match. A combination of high airflow, reaching PWM-controlled speeds up to 2,400 RPM, and high static pressure make LX RGB fans well suited for use as case fans or attached to radiators. CORSAIR AirGuide Technology, with its anti-vortex vanes, also focus airflow direction to move air more efficiently through your case.
Moreover, the LX RGB Series is designed for quiet operation, with Magnetic Dome bearings minimizing friction to ensure low noise and superior longevity. Zero RPM Mode completely eliminates fan noise at low loads, with the fans spinning up only when your system demands it.
Installation is made effortless with CORSAIR’s innovative one-twist QuikTurn screws, empowering you to install a full set of fans in seconds, saving both time and effort. iCUE LINK bridge connectors included with the fans let you stack them directly together to create a seamless bank of fans with no intervening wires, making installation even easier.
