Fractal Design Launches Mood PC Case with Breathable Fabric, Pillar Design, and Compatibility with SFF-Ready Enthusiast NVIDIA GeForce Graphics Cards
Image: Fractal Design
The Mood, a new low-volume PC case that creator Fractal Design says was designed to streamline the gaming station, featuring a space-saving pillar design and breathable fabric on the outer body, has been released, the company announced today. Compatible with SFF-Ready Enthusiast NVIDIA GeForce Cards, this case can fit graphics cards of up to 325 mm in length.
Product links:
Key features:
  • A low-volume case with a minimized footprint thanks to its space-saving pillar design format.
  • Crafted with breathable fabric in a clean shape and color palette designed to harmonize with your home.
  • Choose a graphics card up to 325 mm in length and connect it with the included PCIe 4.0 riser cable.
  • Enjoy effective cooling with the included 180 mm Dynamic fan which moves air up through the case.
  • Pop out the back panel and simply slide off the fabric-covered enclosure for full access to your build.
  • Compatible with radiators up to 280 mm for more ambitious cooling builds or CPU air coolers up to 114
  • mm in height.
  • Start up and connect effortlessly with a front-facing I/O panel which includes a USB Type C 20 Gbps port.
  • Enjoy tool-less removal of the exterior and a range of tying points in the interior for easy cable routing.
  • Includes two accessible 2.5” drive brackets with ball catchers and a mount for a 3.5” drive.
  • Includes a removable, magnet-fastened dust filter.
A feature reel:
Fractal on its new case:
For access to the interior, users can pop out the back panel and simply slide off the fabric-covered enclosure for full access to their build. Inside, Mood can house a graphics card up to 325 mm in length and is compatible with SFF-Ready Enthusiast GeForce Cards. Connecting the graphics card is also made easier thanks to the included PCIe 4.0 riser cable.
For effective cooling, Mood features a 180 mm Dynamic fan at the top which moves air up through the case. For more ambitious cooling builds, there is compatibility for radiators up to 280 mm or CPU air coolers up to 114 mm in height.
