Update 1.12, a new patch that ushers in support for ELDEN RING’s Shadow of the Erdtree expansion, which launches today, is now available, developer FromSoftware and publisher Bandai Namco have announced. Global release timings for the new game have also been shared, as well as updated PC specifications, including minimum and recommended hardware.
New features:
- Added support for the SHADOW OF THE ERDTREE DLC.
- Five new hairstyles have been added to the game. They can be selected during character creation, using the Clouded Mirror Stand or using Rennala’s Rebirth feature.
- Added “Map Functions Menu” to the Map Menu.
- New Summoning Pool features:
- Active Summoning Pools will now be carried over to NG+.
- Individual Summoning Pools can now be enabled / disabled in the newly added Map Functions Menu.
- If “Include Distant Areas” is selected when using the Small Golden Effigy, summoning pools within the Mohgwyn Palace will not be selected for summoning, even if you have activated them.
- If you are within the Moghwyn Palace and select “Nearby Only” when using the Small Golden Effigy, you will be able to be summoned within the area.
New Inventory features:
- Newly obtained items will be marked with a “!“.
- A new tab called “Recent Items” has been added to review recently obtained items.
- Display settings can be changed from the Display tab in the system menu.
- Added new feature to summon spectral steed during the Elden Beast the boss battle.
- Added new feature to the colosseum: crafted consumable items that have been used during a battle will be replenished at the end of your session.
- Added support for Arabic language.
Steam-only new features:
- New Keyboard/mouse settings:
- Added “lock-on change threshold” setting of mouse controls.
- Added a setting to change cursor movement behaviour in the map menu.
- Added key assignments to open the map in the Key Settings menu.
- For the rest of the patch notes, click here.
Global release timings:
Updated PC specs:
A new launch trailer for the expansion:
Game description:
The Shadow of the Erdtree expansion features an all-new story set in the Land of Shadow imbued with mystery, perilous dungeons, and new enemies, weapons and equipment. Discover uncharted territories, face formidable adversaries, and revel in the satisfying triumph of victory. Dive into the riveting interplay of characters, where drama and intrigue intertwine, that create an immersive experience to savor and enjoy.
