ARCTIC has launched the M2 Pro, a new SSD cooler that was specifically designed for M.2 2280 SSDs to ensure reliable performance and longer service life, featuring an extremely compact size at 73 x 24.2 x 10.5 mm. The cooler, which comes with two ARCTIC TP-3 Premium Performance thermal pads, can also be used in Sony’s latest consoles, the PS5 and PS5 Slim, ARCTIC noted.
Product links and spec sheet:
Key features include:
- “For single-sided and double-sided 2280 M.2 SSDs.”
- “Protects against overheating and loss of performance.
- “Easy construction.”
- “TP-3 thermal pads included.”
- “Compatible with Liquid Freezer III.”
A look at its cooling performance:
A promo video:
ARCTIC on its latest cooler:
Small, fast, hot – M.2 SSDs. The compact power packs require additional cooling to ensure consistently high performance. ARCTIC offers the right solution with the M2 Pro.
M.2 SSDs are true speed miracles. However, they tend to reach high temperatures quickly during intensive use and reduce performance early to avoid overheating.
The M2 Pro was specifically designed for 2280 M.2 SSDs. Thanks to its additional mass, it not only keeps the temperature under control, but also ensures that the SSD can cool down more quickly. This enables reliable performance and a long service life.
