“2x the Fans, 2x the Fun”: ASUS Reveals Dual Radeon RX 6500 XT V2 OC Edition 4GB GDDR6 Graphics Card with 2-Slot Design for Broad Compatibility
Image: ASUS
ASUS has updated its website with the Dual Radeon RX 6500 XT V2 OC Edition 4GB GDDR6, a new custom RDNA 2 graphics card that is said to deliver twice the fun courtesy of its cooling solution, which includes a dual axial-tech fan setup, complemented by features that include a protective backplate for preventing PCB flex and a 2-slot design for maximizing compatibility. The GPU, which also advertises dual ball fan bearings for longevity and comes with 1x HDMI (2.1) port and 1x DisplayPort (1.4a), features a boost clock of up to 2,820 MHz.
ASUS’s recent Dual Radeon GPUs now include:
Key features of the Dual Radeon RX 6500 XT V2 OC Edition:
  • “OC edition: up to 2820 MHz (Boost Clock)/up to 2670 MHz (Game Clock).”
  • “Axial-tech fan design features a smaller fan hub that facilitates longer blades and a barrier ring that increases downward air pressure.”
  • “A 2-slot design maximizes compatibility and cooling efficiency for superior performance in small chassis.”
  • “Dual ball fan bearings can last up to twice as long as sleeve bearing designs.”
  • “A protective backplate prevents PCB flex and trace damage.”
  • “Auto-Extreme technology uses automation to enhance reliability.”
A box shot that advertises ASUS’ Auto-Extreme tech for enhanced reliability:
Image: ASUS
ASUS on the new GPU:
Featuring the latest AMD RDNA 2 architecture, ASUS Dual Radeon RX 6500 XT V2 fuses dynamic thermal performance with broad compatibility. Advanced cooling solutions from flagship graphics cards — including two Axial-tech fans for maximizing airflow to the heatsink — are packed into the 20 cm long, 2-slot card, delivering more power in less space. These enhancements make ASUS Dual the perfect choice for gamers who want heavyweight graphics performance in a compact build.
