VAIO Launches World’s Lightest Portable Monitor with Kickstand, Carbon Fiber, and Skeletal Design
Image: VAIO
VAIO Vision+, a new portable monitor that is said to be the world’s lightest mobile display ever, featuring a weight of just 325 grams and a skeletal design with carbon fiber, will be available in Japan beginning this week, VAIO Corporation, the company behind what was once Sony’s PC brand, has announced. The display, which measures 12.4 and 3.9 mm thick at its widest and thinnest points, respectively, features not only a kickstand, but also a origami-style cover stand that allows it to be easily placed above a laptop screen for a dual-monitor setup, according to promo images that VAIO shared.
Availability details:
  • Announcement and order start date and time: July 1, 2024, 10:00
  • Release and earliest delivery date: July 4, 2024
Key features:
  • Portability
    • The world’s lightest, weighing just 325g and measuring just 3.9mm at its thinnest point
    • The back panel of the device is made of three-dimensional molded carbon fiber, which is both lightweight and durable
  • Ease of use
    • 14.0-inch wide display with an aspect ratio of 16:10 for increased productivity
    • Video output and power supply can be used immediately with a single cable
    • Comes with a cover stand that allows for a space-saving two-screen arrangement
  • High quality
    • Made in Japan with all processes from design to implementation and assembly carried out at our Azumino headquarters factory
    • Strict quality testing at the same level as VAIO PCs
    • Thorough pre-shipment check “Azumino FINISH” is carried out
  • Environmental considerations
    • Development of environmentally friendly, highly functional materials and parts
    • New environmentally friendly packaging to deliver products as simply and beautifully as possible, no labels on machine nameplates
    • All electricity used in factories is made from renewable energy
Product specs:
Product name/model nameFor personal use: VAIO Vision+ 14 – VJ5VP141C11
For business use: VAIO Vision+ 14P – VJ5VP141P11
priceFor individuals: 54,800 yen (53,000 yen if purchased together with VAIO SX12/SX14)
For corporations: Open price
massApprox. 325g
ColorAmber Black
External dimensionsApprox. width 312.0mm x height 3.9-12.4mm x depth 211.1mm (excluding protruding parts)
Screen size14.0-inch widescreen (16:10), WUXGA 1920 x 1200 pixels
Main Input/OutputUSB Type-C terminal × 2
(supports the following functions: USB Power Delivery (PD Pass-through), DisplayPort)
accessoriesCover stand
(approx. width 334mm x height 13mm to 18mm (when not stored – when stored) x depth 222mm, approx. 440g)
USB Type-C cable (approx. 1m)
Video Output StandardSupports DisplayPort Alternate Mode
(operation of all devices is not guaranteed)
power supply10W or more recommended (65W or more recommended when charging connected devices)
A promo dump:
VAIO on the display’s light but strong design:
The back panel of the main unit is made of three-dimensionally molded carbon that is both lightweight and strong. Inside, the bosses that join each part and the ribs that support it from the inside are molded as a single unit, reducing the number of materials needed for adhesion, strengthening rigidity and reducing weight. The carbon is bent to the sides and molded three-dimensionally to achieve greater robustness. You can use it with peace of mind even in the unlikely event of stress during rush hour or impact when dropped.
