MSI MPG 341CQPX and MAG 271QPX E2 QD-OLED Gaming Monitors Feature 240Hz Refresh Rate and 0.03ms Response Time
Image: MSI
The MSI MPG 341CQPX and MAG 271QPX E2 are the latest additions to its QD-OLED gaming monitor portfolio. Both monitors feature HDMI 2.1 (48 Gbps), DP 1.4, and USB Type-C connectivity. The MSI MPG 341CQPX and MAG 271QPX E2 each support up to 240 Hz with a 0.03ms response time and 120 Hz Adaptive Sync VRR and ALLM. They are both VESA certified for ClearMR 13000 and DisplayHDR True Black 400 to provide the best image quality while adapting to motion blur.
Other features for each include OLED Care 2.0 to reduce OLED burn-in risks, graphene film with custom heatsink, fan-less design, and a 3-year OLED burn-in warranty. Each can provide a brightness of up to 250 nits for SDR content and up to 1000 nits for HDR content with their 10-bit displays. MSI has not yet revealed product availability or pricing for these new monitors.
Image: MSI
MPG 341CQPX QD-OLED Specs (via datasheet):
Some things that set the MSI MPG 341CQPX apart from the MAG 271QPX QD-OLED E2 are its 34″ 21:9 ultrawide aspect ratio, 98W power delivery, and 1800R curvature. Additional 2x USB 2.0 Type-A and 1x USB 2.0 Type-B ports are also included.
  • Panel Size: 34.18“ (86.82cm)
  • Active Display Area: (mm) 800.06(H) x 337.06(V)
  • Curvature: 1800R
  • Panel Type: QD-OLED
  • Panel Resolution: 3440 x 1440 (UWQHD)
  • Pixel Pitch: (H x V) 0.2315(H) x 0.2315(V)
  • Aspect Ratio: 21:9
  • Brightness (nits): SDR:250 nits, HDR:450 nits (Typ.) (True Black 400 with 10% APL), 1000 nits (Typ.) (Peak 1000 with 3% APL)
  • Contrast Ratio: 1500000:1
  • DCR: N/A
  • Signal Frequency: 30~390 KHz(H) / 48~240 Hz(V)
  • ACTIVATED RANGE: 48~240Hz
  • Refresh Rate: 240Hz
  • Response time: 0.03ms (GTG)
  • DYNAMIC REFRESH RATE TECHNOLOGY: Adaptive-Sync
  • HDR Support: DisplayHDR True Black 400
  • Video ports: 1x Display Port 1.4a, 2x HDMI™ 2.1(UWQHD@240Hz), 1 x USB 2.0 Type-C (DP alt.) w/ 98W PD
  • USB ports: 2x USB 2.0 Type-A, 1x USB 2.0 Type-B
  • Audio ports: 1 x Headphone-out
  • Viewing Angle: 178° (H) / 178° (V)
  • Adobe RGB / DCI-P3 / sRGB: 97.8% / 99.3% / 139.1%
  • Surface Treatment: Anti-Reflection
  • Display Colors: 1.07B, 10-bit
  • Power Type: Power Cable
  • Power Input: 100~240V, 50/60Hz
  • Adjustment (Tilt): -5° ~ 20°, (Swivel): -30° ~ 30°, (Height): 0 ~ 100mm
  • Kensington Lock: Yes
  • Dimension (W x D x H): 812 x 318 x 427mm, 812 x 130 x 361mm (without stand)
  • Carton Dimension (W X D X H) WW carton: 1000233513mm, Outer: 1015248536mm
  • Frameless Design: Yes
  • PIP / PBP Function: Yes
  • VESA Mounting: 100 x 100 mm
  • Weight (NW / GW): 8.8kg / 12.45kg, 6.66kg (without stand)
  • Note: Display Port: 3440×1440 (Up to 240Hz), HDMI™: 3440×1440 (Up to 240Hz), Type C(DP alt.): 3440 x 1440 (Up to 240Hz) and 98W PD *Adobe RGB, DCI-P3 and sRGB follow CIE1976 Standard
  • Warranty: 3 years (including panel burn-in)
Image: MSI
MAG 271QPX QD-OLED E2 Specs (via datasheet):
The 271QPX QD-OLED E2 includes nearly all of the same features of its 34-inch counterpart sans the extra USB ports and only supports up to 15W PD. It is designed with a more traditional flat 16:9 aspect ratio panel.
  • Panel Size: 26.5“(67.31cm)
  • Active Display Area: (mm) 590.42(H) x 333.72(V)
  • Curvature: Flat
  • Panel Resolution: 2560×1440 (WQHD)
  • Pixel Pitch: (H x V) 0.2292(H) x 0.2292(V)
  • Aspect Ratio: 16:9
  • with 10% APL), 1000 nits (Typ.) (Peak 1000 with 3% APL)
  • Contrast Ratio: 1500000:1 (Typ.)
  • DCR: N/A
  • Response time: 0.03ms (GtG)
  • Video ports: 1 x DisplayPort (1.4a), 2 x HDMI™ 2.1 (WQHD@240Hz), 1 x USB 2.0 Type-C (DP alt.) w/ 15W PD
  • USB ports: N/A
  • Viewing Angle: 178°(H) / 178°(V)
  • Adobe RGB / DCI-P3 / sRGB: 98% / 99.1% / 138.4%
  • Adjustment: (Tilt) -5° ~ 20°, (Swivel) -30° ~ 30°, (Pivot) -90° ~ 90°, (Height) 0 ~ 110mm
  • Dimension (W x D x H): 609 x 242 x 416mm, 609 x 72 x 362mm (without stand)
  • Carton Dimension (W X D X H): WW carton: 800 x 185 x 500mm, Outer: 818 x 200 525 mm
  • Weight (NW / GW): 8 kg / 10.3 kg
  • Note: Display Port: 2560 x 1440 (Up to 240Hz), HDMI 2.1: 2560 x 1440 (Up to 240Hz), Type C(DP alt.): 2560 x 1440 (Up to 240Hz) and 15W PD charging *Adobe RGB, DCI-P3 and sRGB follow CIE1976 Standard
