The Lian Li EDGE PSU series aims to make it even easier to build in a dual chamber chassis with its L-shaped form factor. Models are available in 850W, 1000W, and 1300W, with an efficiency rating of 80 PLUS PLATINUM / Cybenetics PLATINUM / PPLP PLATINUM. There is also an 850 Gold-rated model with a mesh cover. The Lian Li EDGE PSU series provides all the connectors one would expect to find on a current ATX 3.1 power supply but goes a step further in adding a USB expansion hub that can support multiple controllers.
Pricing and Availability (per product page):
The Lian Li Edge series featuring the L-shaped design launches on July 13 with some models available in black or white. MSRP Pricing will be as follows: EG8550($149.99), EG1000(189.99-black/199.99-white), EG1300($229.99-black,$239.99-white), EG850 Mesh($119.99). All come with a 10-year warranty except for the EG850 Mesh, which has a shorter 7-year warranty.
EG1300 Specifications (per product page):
- MODEL: EG1300
- DIMENSIONS: (D)182 mm X (W)86 mm X (H)150 mm
- POWER SUPPLY DESIGN: Fully modular
- COLOR: Black/ White
- MATERIAL: Steel,Plastic
- FORM FACTOR: ATX 3.1
- CERTIFICATION: 80 PLUS PLATINUM / Cybenetics PLATINUM / PPLP PLATINUM
- MAX. DC OUTPUT: 1300W
- COMBINED +3.3V & +5V: 120W
- COMBINED +12V: 1296W
- INPUT VOLTAGE: 100-240Vac
- INPUT FREQUENCY RANGE: 15-7.5A 50-60Hz
- PFC: Active PFC, PF > 0.90 under full load @ 115Vac, 60Hz
- EFFICIENCY: 92.39% MAX
- PROTECTIVE CIRCUIT: OCP/OVP/OTP/OPP/SCP/UVP
- CONNECTORS: 1 x 24/20-Pin motherboard connector (500mm) x1pcs, 1 x 8/4+4 Pin CPU/ATX 12V connector (550mm) x2pcs, 1 x 8/6+2 Pin PCle connector (550m m) x4pcs, 1 x 12VHPWR connector (550mm) × 1pcs, 1 x 12VHPWR – 2 x 8pin connector (550mm) × 1pcs, 4 x 4-Pin Peripheral connector (500mm-150mm-150mm- 150mm) x1pcs, 4 x SATA connector (400mm-150mm-150mm-150mm) x1pcs, 4 x SATA connector (300mm-15mm-15mm-15mm) x 1pcs, 4 x Y Type SATA connector (400mm-125mm*2) x1pcs, USB*9pin – USB*9pin connector (350mm) × 1pcs, USB*9pin -Type A connector (550mm) × 1pcs
- FAN TYPE: 120mm FDB Fan
- FAN RPM: 2400RPM
- FAN NOISE LEVEL: 33.61dBA
- WARRANTY: 10 Years
