GIGABYTE Launches AI- and SFF-Ready GeForce RTX 4070 Ti SUPER AI TOP 16G Graphics Card
Image: GIGABYTE
GIGABYTE has launched the NVIDIA GeForce RTX 4070 Ti SUPER AI TOP 16G, a new SFF-Ready Enthusiast graphics card that appears to be the first to be sold under what the company has described as a groundbreaking solution for local AI, introduced by GIGABYTE last month to further fuel the growth in generative AI. The graphics card, which features a blower fan and 2610 MHz core clock, is available for $880, according to fresh listings from retailers that include Newegg.
Key features include:
  • Powered by NVIDIA DLSS 3, ultra-efficient Ada Lovelace arch, and full ray tracing
  • 4th Generation Tensor Cores: Up to 4x performance with DLSS 3 vs. brute-force rendering
  • 3rd Generation RT Cores: Up to 2X ray tracing performance
  • SFF-Ready Enthusiast GeForce Card
  • Powered by GeForce RTX 4070 Ti SUPER
  • Integrated with 16GB GDDR6X 256bit memory interface
  • Turbo Fan cooling system
  • Optimized airflow design for multiple cards
  • All copper cooling & metal frame
  • Double ball bearing fan
  • Protection metal back plate
A look at the cooling system:
Image: GIGABYTE
GIGABYTE on its AI GPU:
The GeForce RTX 4070 Ti SUPER AI TOP graphics card is specifically designed for AI computing. It features the Turbo Fan cooling system, ULTRA DURABLE materials, and double ball bearing structure, providing stable and powerful AI computing capabilities, even in demanding multi-card setups or under prolonged use. The graphics card has passed GIGABYTE’s high-quality verification and undergone specialized simulation tests for AI computing scenarios to ensure optimal performance during AI operations.
The graphics card is equipped with 8448 CUDA cores and 264 Tensor cores, as well as up to 16GB of GDDR6X high-speed memory. When multiple cards are used together, they can provide powerful support for AI computing.
