Corsair Launches 3500X Series Mid-Tower Cases with Wraparound Glass View and Compatibility with BTF/Project Zero Motherboards
Image: Corsair
The 3500X Series, a new lineup of mid-tower PC cases that are said to offer a blend of aesthetics, compatibility, and cooling performance at an affordable price, is now available to order starting at $89.99 in black or white color options, Corsair has announced. These cases, which are also available in ARGB and ICUE Link versions, are headlined by their wraparound tempered glass panels, enabling an unobstructed view of hardware, as well as compatibility with BTF and Project Zero reverse-connector motherboards, ASUS and MSI’s answer to reducing cable clutter.
Product links:
CORSAIR 3500X ARGB Mid-Tower PC Case
$119.99
$79.99
Corsair.com
CORSAIR 3500X ARGB Mid-Tower PC Case - White
$119.99
$79.99
Corsair.com
CORSAIR 3500X Mid-Tower PC Case
$99.99
Corsair.com
CORSAIR 3500X Mid-Tower PC Case - White
$99.99
Corsair.com
CORSAIR iCUE LINK 3500X RGB Mid-Tower PC Case
$159.99
$99.99
Corsair.com
CORSAIR iCUE LINK 3500X RGB Mid-Tower PC Case - White
$159.99
$99.99
Corsair.com
    Key features include:
    • Wraparound glass view with removable front and side panels
    • 3x Pre-installed RS120 ARGB fans (ARGB edition)
    • 3x Pre-installed iCUE LINK RX120 fans with iCUE LINK System Hub (iCUE Link edition)
    • Builder-friendly features for a high-performance custom PC
    • Side, roof, and PSU fan mounting points for great cooling
    • Compatible with ASUS BTF and MSI Project Zero reverse connection motherboards
    A promo video:
    Corsair on its latest case:
    With wide component compatibility to accommodate high-performance PCs, versatility forms the cornerstone of the 3500X’s design philosophy. This new case supports motherboard form-factors from Mini-ITX to EATX and is compatible with the newer reverse connector motherboards such as ASUS BTF and MSI Project Zero, enabling a pristine view free of unsightly cables. With a spacious interior that fits most large graphics cards and air coolers, the 3500X is ready to house your next high-powered gaming rig.
    You don’t have to sacrifice cooling performance for the sleek, wraparound tempered glass aesthetic of the 3500X either, thanks to strategically placed fan mounting points on the side, roof, and bottom of the case to provide ample airflow. Beyond that, the 3500X can accommodate radiators up to 360mm in the roof or side, enabling the use of robust Hydro X Series custom cooling solutions or a top-performing all-in-one CORSAIR liquid CPU cooler.
    Available in black or white, the 3500X Series offers three distinct options to match your build preferences: the iCUE LINK 3500X RGB with an included iCUE LINK System Hub and three RX120 RGB fans – the perfect starting point for a state-of-the-art iCUE LINK system; the 3500X ARGB with three pre-installed RS120 ARGB fans for simple motherboard-controlled lighting, or the standard 3500X case for those who want to utilize their existing fans.
