The RS Series, a new lineup of cooling fans that are said to be ideal for PC builders seeking precise PWM cooling without the need for additional controllers, featuring simple daisy-chained connections for a hassle-free setup, are now available in 120 mm and 140 mm sizes, in both single and multi-fan packs, Corsair has announced. Customers can choose between non-ARGB and ARGB versions, the latter of which delivers what Corsair has described as eye-catching addressable lighting.
Product links:
Key features include:
- Daisy-chained 4-pin PWM connectors
- Daisy-chained +5V ARGB lighting with eight LEDs per fan (ARGB versions)
- CORSAIR AirGuide technology for concentrated airflow
- CORSAIR Magnetic Dome bearing for longevity and low noise
- Zero RPM mode at low loads
A promo video:
Corsair on its new fans:
RS fans streamline cable management within your build when you daisy-chain one fan to the next, all connected to your motherboard using a single 4-pin PWM connector. RS ARGB fans add dynamic lighting to your build without unnecessary complexity by utilizing one +5V ARGB header. This streamlined approach makes installation a breeze, putting control of fan speeds and lighting right at your fingertips via your motherboard.
During low-load conditions, Zero RPM Mode support eliminates fan noise by stopping the fans from spinning when they’re not needed. The RS Series incorporates CORSAIR AirGuide Technology, the market-proven feature in modern CORSAIR fans that helps direct airflow precisely where it’s needed with anti-vortex vanes. Additionally, the renowned CORSAIR Magnetic Dome bearing minimizes noise and friction while ensuring a longer lifespan for the fans, resulting in a well-rounded fan with exceptional value.
