GIGABYTE has shared the official specifications for the B650E AORUS STEALTH ICE, a new motherboard that is said to be the world’s first true white reverse connector motherboard, featuring a unique all-white appearance that makes it stand out among its competitors. First unveiled at COMPUTEX 2024, this motherboard boasts the highest back-insert compatibility in the industry, according to GIGABYTE, whose chassis support list includes the likes of Cooler Master, Lian Li, Corsair, and other popular case manufacturers.
Key features include:
- AMD Socket AM5:Supports AMD Ryzen 9000/8000/7000 Series Processors
- Digital twin 12+2+2 phases VRM solution
- Dual Channel DDR5:4*DIMMs with AMD EXPO Memory Module Support
- PCIe UD Slot X: PCIe 5.0 x16 slot with 10X strength for graphics card
- WIFI EZ-Plug: Quick and easy design for Wi-Fi antenna installation
- M.2 EZ-Match: Magnetic alignment for easy installation of large heat sinks
- EZ-Latch Click:M.2 heatsinks with screwless design
- EZ-Latch Plus:M.2 slots with Quick Release & Screwless Design
- Sensor Panel Link:Onboard video port for hassle-free in-chassis panel setup
- UC BIOS:User-Centred intuitive UX with Quick Access function
- Back Plate : With an iron base plate providing enhanced stability and support, this design not only boasts an attractive appearance but also excels in functionality.
- Ultra-Fast Storage:3*M.2 slots, including 1* PCIe 5.0 x4
- Efficient Overall Thermal:VRM Thermal Armor Advanced & M.2 Thermal Guard XL
- Fast Networking:2.5GbE LAN & Wi-Fi 7 with Ultra-high gain directional antenna
- Extended Connectivity:HDMI, Onboard HDMI, USB-C with DP-Alt
- Reliable Audio:8-Ch HD Audio & Audiophile Grade Capacitors
- World’s First true White Reverse Connector Motherboard
A look at the rear connectors, including I/O connectivity:
GIGABYTE on the motherboard’s stealth design:
Not just a PC build kit, Stealth Series Product delivers a revolutionary building experience. By having virtually no wire and cable cluttering, a faster assembly time, smoother directional airflow, and better performance, flaunt a cableless seeming desktop with unrestricted space.
