Phanteks is announcing two new products for PC enthusiasts and builders today: the AMP GH, an ATX 3.1 power supply that combines advanced technology with user-friendly features, including PCIE Gen 5.1 GPU support, a 120 mm hydraulic bearing fan, and hybrid fan control with a zero RPM mode for silent operation; and the Polar ST, a new series of CPU coolers that is said to deliver high performance and exceptional value, featuring sintered powder copper heat pipes and available in two variants. Details on availability and pricing can be found below.
Product links:
- POLAR ST5 (All-black heatsink with 5x heat pipes)
- POLAR ST4 (Entry-level with 4x heat pipes)
- AMP GH | White (750/850/1000 watts)
- AMP GH | Black (750/850/1000 watts)
Availability:
- AMP GH
- United States – Not Available Yet
- Europe – Pre-order Available Now!
- Polar ST
- United States—Available Now!
- Europe – Available in August!
MSRP:
- AMP GH 750W GOLD – Black: $99.99 | €99.90 | £84.99
- AMP GH 750W GOLD – White: $109.99 | €109.90 | £94.99
- AMP GH 850W GOLD – Black: $119.99 | €119.90 | £104.99
- AMP GH 850W GOLD – White: $129.99 | €129.90 | £114.99
- AMP GH 1000W Platinum – Black: $149.99 | €149.90 | £128.99
- AMP GH 1000W Platinum – White: $159.99 | €159.90 | £138.99
- Polar ST4 – 120 DRGB Black: $19.99 | €24.90 | £21.90
- Polar ST5 – 120 DRGB Black: $24.99 | €29.90 | £25.90
Key features include:
- AMP GH Power Supplies
- Individual Textured Cables: Clean cable management to keep builds nice and tidy.
- PCIE Gen 5.1 GPU Support: Supports next-gen GPU with up to 600W through a single cable.
- 120mm Hydraulic Bearing Fan: Enhanced stability and longevity.
- Compact ATX Size: Ultra-high-power density in a 140mm depth.
- ATX 3.1 Specifications: Upcoming CPU and GPU support. Handles high power peaks up to 200% of its rated power output.
- Hybrid Fan Control: Zero RPM mode for silence under low loads.
- Polar ST CPU Coolers
- Sintered Powder Copper Heat Pipes: Superior thermal conductivity.
- M25-120 Fans: Wide RPM range for optimal cooling.
- Efficient Design: Maximizing cooling performance.
- Sleek Design: Fits seamlessly on any motherboard without RAM clearance issues.
Some product shots:
Phanteks on its new PSU:
…these units revolutionize cable management with sleek, individually textured cables for a pristine setup. Enhanced with a 120mm Fluid Dynamic Bearing Fan, they deliver temperature-controlled operation in Hybrid Fanless mode, ensuring virtually silent performance.
With the latest PCIe Gen 5.1 GPU cable technology, the 12V-2×6 connector delivers up to 600W of power via a single cable. Engineered to meet ATX 3.1 specifications, the Phanteks AMP GH represents a superior and cost-effective choice for high-performance builds.
