G.SKILL Announces DDR5-6400 CL30 Low Latency DDR5 Memory Specification for Trident Z5 Series in 32 GB Kit Capacity
Image: G.SKILL
The Trident Z5 RGB and Trident Z5 Royal DDR5 memory series with Intel Extreme Memory Profile (XMP) 3.0 support are set to expand with the release of a new overclock memory specification, one that will deliver DDR5-6400 CL30-39-39-102 in 32GB (2x16GB) kit capacity, G.SKILL has announced. This new specification, which the company describes as being high performance, will also be available under the Trident Z5 Neo RGB and Trident Z5 Royal Neo series, which feature AMD EXPO overclock profile support.
Availability details:
  • Through G.SKILL worldwide distribution partners
  • Starting late August 2024
G.SKILL on how it’s pushing the CL limits of DDR5-6400:
  • “The G.SKILL R&D team strives to push the limits of memory performance, and low latency is a key factor in memory overclocking for enthusiasts and overclockers.”
  • “Compared to the standard DDR5-4800 CL40, this new DDR5-6400 CL30 specification makes improvements upon the memory speed and latency.”
  • “And since this is a high-performance specification, it’s important to check the compatibility of the motherboard and CPU.”
A look at both series:
About G.SKILL:
Established in 1989, G.SKILL specializes in high-performance memory and provides PC component and peripheral products designed for PC gamers, professionals, overclockers, and enthusiasts around the world. Combining technical innovation and rock solid quality through our in-house memory testing lab and talented R&D team, G.SKILL continues to create ultra-performance overclock memory for each platform generation.
