AMD Ryzen 9 9900X CPU Review: 12-Core Zen 5 at $499
Synthetic System Benchmarks
On this page, we will show synthetic benchmarks, some that test a variety of system use-case scenarios, and others that test specific multi-core and single-core/thread workloads to hone in on performance differences. Note that the graphs are arranged from fastest to slowest, and the AMD Ryzen 9 9900X CPU is highlighted. One of the primary goals while reading the performance is to see the difference between the Ryzen 9 9900X and Ryzen 9 7900X. Of course, the competition is included as well and we are showing both the Extreme Profile and Performance Profile BIOS settings. Take note that Core/Thread count differences will affect many results in multi-core/multi-thread testing.
PCMark 10 Express
PCMark 10 Express tests workloads as follows: PCMark 10 Express is a benchmark that focuses on basic work tasks. It is a good choice when tendering for PCs for general office use. The PCMark 10 Express benchmark focuses on the performance needs of a typical office worker. It tests Essentials and Productivity.
AMD Ryzen 9 9900X PCMark 10 Express Benchmark Performance Graph
This benchmark focuses mainly on workloads that are more lightly threaded in office applications. Right off the bat, the new 12-core AMD Ryzen 9 9900X is near the top of the graph, with the second-to-most performance at 7930. If we compare it to the previous generation Ryzen 9 7900X, then the AMD Ryzen 9 9900X is a small 3% faster, which is not a big performance difference in this lightly threaded workload. When we compare this to the Intel Core i9-14900K in the Performance Profile, it is at least 3% faster.
Geekbench 6
We are using Geekbench version 6.3.0 for our testing. We will show Multi-Core (nT) and Single-Core (1T) performance in separate graphs.
AMD Ryzen 9 9900X Geekbench 6 CPU Benchmark Multi Core Performance Graph
In Geekbench 6’s Multi-Core testing, the AMD Ryzen 9 9900X looks better with an 8% uplift compared to the previous generation Ryzen 9 7900X. In fact, the 12-core AMD Ryzen 9 9900X actually ends up having the same performance on Multi-Core as the 16-core Ryzen 9 7950X from the previous generation! That’s a pretty impressive positioning for the new AMD Ryzen 9 9900X to be in considering it is just 12-cores/24-threads. It is about 9% slower than the Intel Core i9-14900K in Performance Profile, however.
AMD Ryzen 9 9900X Geekbench 6 CPU Benchmark Single Core Performance Graph
The new AMD Ryzen 9 9900X has a more impressive 11% uplift in Single-Core performance compared to the Ryzen 9 7900X in the previous generation. At this single-core performance uplift, the new AMD Ryzen 9 9900X is actually also 11% faster than the Ryzen 9 7950X. It also outperforms the Intel Core i9-14900K by 4%.
3DMark CPU Profile
We are testing 3DMark’s CPU Profile which tests Max Thread performance and Single Thread performance, we are reporting both on separate graphs.
AMD Ryzen 9 9900X 3DMark CPU Profile Max Threads Performance Graph
The 3DMark Max Threads test shows that the AMD Ryzen 9 9900X provides a 7% performance uplift compared to the previous generation AMD Ryzen 9 7900X. This puts it under the other CPUs, however, due to the 12-core nature. It ends up being 12% slower than the Intel Core i9-14900K in the Performance Profile.
AMD Ryzen 9 9900X 3DMark CPU Profile 1-Thread Performance Graph
Once again, though, in the 1-thread performance, the new AMD Ryzen 9 9900X is doing very well at 14% better performance than the previous generation Ryzen 9 7900X. Therefore, at this performance level, it actually ends up also being faster than the Ryzen 9 7950X in 1-thread performance. It’s also 2% faster than the Intel Core i9-14900K.
PerformanceTest 11
AMD Ryzen 9 9900X PerformanceTest 11 PassMark CPU Mark Performance Graph
In PassMark PerformanceTest 11 CPU Mark result the AMD Ryzen 9 9900X ends up being just 5% faster than the AMD Ryzen 9 7900X from the previous generation. This puts it 12% behind the Intel Core i9-14900K and 13% behind the 7950X.
Performance
Efficiency (Perf per Watt)
7
We reviewed the AMD Ryzen 9 9900X CPU Review, AMD's 12-core high-end desktop AM5 Zen 4 architecture based CPU at an MSRP of $499. It offers good performance, with an uplift mainly in single-thread performance and AVX workloads, but does not gain as much in multi-threading or lighter office type of workloads. It is a very efficient CPU, with a lower power draw, and runs cool loaded with features. It's value is hurt by the currently priced Ryzen 9 7900X, but over time, it should start to look more appealing.
