“New Performance King”: Corsair Launches Its Best-Performing Cooler Ever for AMD and Intel CPUs
Image: Corsair
The iCUE LINK TITAN RX RGB, a new series of AIO coolers that maker Corsair says is the best-performing cooler that it has ever created, developed after thousands of hours of in-house engineering, is now available from the Corsair webstore and its worldwide network of authorized retailers and distributors, Corsair has announced. The new cooler, which features 20 RGB LEDs on the pump and up to three RGB fans, is headlined by FlowDrive, a cooling engine that features a three-phase motor to deliver a higher flow rate and other improvements versus its predecessors.
CPU support includes:
  • Intel LGA 1851/1700
  • AMD AM5/AM4
Product links:
Key features for the 360 mm model:
  • “Extreme cooling performance with streamlined iCUE LINK connectivity.”
  • “FlowDrive cooling engine with three-phase motor for peak thermal efficiency.”
  • “Three high-performance RX120 RGB fans.”
  • “20 RGB LEDs on the pump plus eight per fan create dynamic lighting.”
  • “Personalize your cooler with tool-free CapSwap modules (sold separately).”
A look at the new cooler:
Corsair on its latest cooler:
Driving the TITAN RX RGB’s phenomenal performance is the new FlowDrive cooling engine, powered by a three-phase motor that offers improved power efficiency, quieter operation, and a higher flow rate than its predecessors. This, combined with a precision-engineered cold plate surface profile that ensures optimal contact with your CPU’s integrated heat spreader, results in consistently lower temperatures under all conditions. With the inclusion of CORSAIR’s top-performing RX RGB fans, specifically engineered for the high airflow and static pressure needed for radiator cooling, the TITAN RX RGB provides exceptional cooling performance with impressively low acoustics.
Accompanying the vibrant lighting of the RX RGB fans, a new pump cap featuring a captivating design showcases 20 individually addressable RGB LEDs. The TITAN RX RGB also offers additional ways to personalize your cooler using unique CapSwap modules (sold separately). These modules let you change the look or functionality of the cooler in seconds, completely tool-free. Add depth to your lighting with the three-dimensional Groove module, reduce motherboard VRM, M.2, and DRAM temperatures by as much as 25°C with the VRM Fan module, or display anything from system temps to animated GIFs on the popular LCD Screen module.
The TITAN RX RGB leverages CORSAIR iCUE LINK technology, enabling effortless, simplified connections that make cable management a breeze. Coupled with more intelligent, bi-directional communication between each component and iCUE software, it’s easy to see why iCUE LINK is the future of DIY PC building.
