The Radeon RX 7600 OC, a new RDNA 3 graphics card that is said to deliver the best bang for the buck, offering casual and mid-range gamers what’s been described as excellent 1080p performance with 8 GB of GDDR6 memory and a boost clock of up to 2,726 MHz, is coming to retailers, BIOSTAR has announced. Connections for the new GPU, which is also available in a non-OC version, include 3x DisplayPort 2.1 and 1x HDMI 2.1.
Product links:
Key features for the OC model include:
- CUDA Cores/Stream Processors: 2048
- Engine Clock (Base/Boost): 2318/2655 MHz
- Memory Clock: 18 Gbps
- Memory Type: GDDR6
- Memory Size: 8 GB
- Memory Bus: 128-bit
- Interface: PCIe 4.0
- Output: 3x Display Port 2.1, 1x HDMI
- Recommended PSU: 550 watts
- Power Connectors: 8-pin x1
- Card Size: 235x150x45 mm
Some additional shots:
BIOSTAR on its new GPU:
The RX 7600 OC is packed with impressive specs that deliver consistent, reliable gaming performance. With 8GB of GDDR6 memory and a 128-bit bus, it’s optimized for smooth 1080p gaming across a wide range of titles.
The RX 7600 OC thrives when pushed beyond its factory settings, demonstrating impressive resilience and performance. True to its OC title, the card features impressive overclocking capability. With a base clock speed of 2318MHz from the factory, the RX 7600 OC can boost up to 2726MHz, delivering faster frame rates, reduced rendering times, and a smoother, more immersive gaming experience.
Supporting PCIe 4.0, HDMI 2.1, and three DisplayPort 2.1 outputs, the RX 7600 OC offers flexible connectivity for multiple monitors and high-refresh-rate setups. Powered by AMD’s RDNA3 architecture, this card also integrates advanced features like Radeon Anti-Lag and AMD Noise Suppression, ensuring smooth, responsive gameplay while maintaining efficiency during demanding tasks.
The BIOSTAR Radeon RX 7600 OC redefines the gaming experience for casual and mid-range gamers with advanced overclocking capabilities and versatile connectivity options. Combining cutting-edge technology, robust performance, and remarkable value for its price, the RX 7600 OC is ideal for those seeking a seamless, enjoyable gaming experience at 1080p.
