The Thermaltake G700 RGB Gaming Desk Featuring Cable Management Options and Dual Monitor Support Is Now Available to Order
Image: Thermaltake
The Thermaltake G700 RGB gaming desk is designed with a range of features to assist users in creating for a clean-looking optimal setup. While not the lowest-costing gaming desk out there the Thermaltake G700 RGB desk does offer quite a bit for its $1,099.99 price. The premium desk is presently only available in black but Thermaltake has said that a “snow” edition is forthcoming. Thermaltake debuted the G700 at CES 2024.
The G700 provides a large space with its 163(L) x88(W) x2.5(H) cm surface area that includes a hidden cable management compartment that contains a flip-open lid, magnetic cable organizers, dynamic glide dual monitor mounting system, dual-motor drive height adjusting system, anti-collision safety sensor, RGB lighting strip, and a cloth full-sized 160cm x 65.5cm mouse pad.
Features:
  • “Through the special dynamicscreen glide design, allows you to easily move the screen position around with one button to maximize the flexibility of desktop use, facilitating multi-dimensional transformation.”
  • “Also, with a distinctive two-piece tabletop design the rear tabletop being flip-open, providing direct access to the cable management compartment below, ensuring a tidy workspace and igniting creativity.”
  • “G700 equipped with two magnetic cable organizers that can be attached to designated areas on the desktop to help you keep your cables neatly organized to the to the cable management compartment.”
  • “The unique dual-motor drive system ensures that the G700 rises and falls smoothly, providing a steady and safe working environment. The up and down speed is 35mm/s, with a rising and falling height of 610-1250mm and a load bearing of 130 kg. Moreover, the system produces less than 46 decibels of noise.”
  • “For your safety, we’ve included an anti-collision safety sensor to automatically detect when the desk encounters obstacles while elevating your gaming desk.”
  • “Designed with an optimized full cloth mouse pad surface(160cm x 65.5cm) and semi-coarse textured weave. G700 enhanced mouse tracking and balanced gameplay.”
  • “The smart controller panel features durable black switches and can set up to 2 height memory settings, and offer a safety lock and collision sensitivity management. What’s more, take it a step further and choose between 7 different lighting effect settings(Static, Colorful Neon, Flicker, Colorful Flicker, Reactive, Spectrum Running)”
Specifications ( per Thermaltake):
  • Motor
    • Voltage : Input 110V / Input 240V
    • Speed: 35mm/s
    • Motor: Two motor with three-stage lifting system
    • Duty cycle: 10%. Max 2 mins on/ 18 mins off.
    • Safety certifications : Motor: CE
  • Controller
    • Standard 2-Button: Descend buttons, Ascend buttons
    • Memory: 2 Memory Settings
    • RGB: Lighting Control
    • Function: Safety Lock & Collision Sensitivity Setting
  • Desktop
    • Size : 160cm(L) x 88.7cm(W) | 62.99″(L) x 34.92″(W)
    • Desktop thickness: 2.5 cm / 0.98″
    • Material: Particle Board
    • Furniture Finish: Black
    • Scratch coating: Yes
    • RGB LED Lighting Strip: 16.8 million colors
