Title Update 1.1.2, a new patch that delivers several improvements for Star Wars Outlaws, including PC performance optimizations, various bug fixes, and VRAM improvements, is now available for download, Ubisoft and Massive Entertainment have announced. The new patch, which weighs in at 1.89 on PC, also adds cross-progression through Ubisoft Connect, allowing player to access their saved games between all platforms, as well higher graphic fidelity when using ray reconstruction and frame generation.
HIGHLIGHTS:
- Tweaks and improvement on some challenging stealth moments.
- Cross-progression and saving is now available.
- Overall PC performance improvement and optimization.
- Crash fixes and stability improvements across all platforms.
- “Old School Cool” trophy can now be unlocked for PlayStation 5 players so you can finally platinum the game!
- The “Hyperspace” mission is fixed, you can now take off.
- Various bug fixes affecting quest flow.
Patch Sizes:
- PlayStation 5: 1.92 GB
- Xbox Series X|S: 2.25 GB
- PC: 1.89 GB
New Feature:
- Cross-progression and saving is now available between all platforms through Ubisoft Connect. More info on this here.
Performance & Stability:
- Various crash fixes and stability improvements across all platforms.
- PC performance improvements and optimization across the game.
- Improvement for FPS drops during some scenes.
- VRAM Improvement.
- Higher graphic fidelity when using ray reconstruction and frame generation technologies.
UI, HUD and Settings:
- Game version will now be visible from the settings.
- Quality mode will be set as default on console.
- Corrected default settings for motion blur on quality mode for consoles.
- HDR Brightness values have been modified.
Graphics:
- Various graphics and lighting fixes.
- All cinematics now supported on ultra-wide screens.
Audio:
- Fix for potential music loss when fast-travelling in Toshara.
Worlds, Fauna and Flora:
- Many additional idle animations for NPC have been added across all planets.
- Fixed an issue where the Imperial Speeder Bike 74-z would be missing a part.
General Gameplay:
- It is now less likely to be detected while rolling.
- Level of detection adjusted depending on location.
MAIN & SIDE QUESTS (BEWARE OF SPOILERS):
- Toshara
- Fixed the issue where the energy barrier in Kerro’s Speakeasy would not be disabled after successfully slicing the terminal.
- “The Underworld” – NPC numbers have been adjusted and environmental guidance markers added to better facilitate infiltration.
- “The Mechanics”- Fixed the issue where Kay would spawn outside the quest area if she died inside the wind turbine.
- “The Wreck” – AI detection has been adjusted.
- “Hyperspace” – Fixed the issue where no prompt was shown to take off.
- Tatooine
- “Partners” – Fixed the issue where Kay would not gain wanted levels on other planets when reaching the objective “Meet with Hoss in the cantina”.
- Akiva
- “The Veteran” – Fixed the issue where “reporting to the droid” objective would not update after reporting back to MT-7.
Miscellaneous:
- “Old School Cool” trophy can now be unlocked for PlayStation 5 players.
- Inverting one axis in the controls menu will no longer invert the other one in Photo mode.
- Nix accessories and treats can now be checked in the loadout menu while Kay Vess is piloting the Trailblazer.
A note from Massive:
…we would like to thank you all for the amazing positivity and support following the launch of Star Wars Outlaws! Your passion, love for Kay, Nix, our Open World and all your amazing creations through our Photo mode has been a real inspiration for the whole team.
