The ROG Strix Platinum PSU series, a new family of ATX 3.1 power supplies that maker ASUS says is ideal for gaming PC setups, featuring several innovations that include “GPU-First”—a voltage sensing technology that is said to enhance GPU power delivery by up to 45% for higher gaming and overall performance—is coming to retailers in 1,200-watt, 1,000-watt, and 850-watt versions, ASUS has announced. All of these PSUs, which are 80 PLUS Platinum certified, feature a native 12V-2×6 connector for powering supported GPUs and graphics cards.
Product links:
ASUS on “GPU-First” voltage sensing:
- “The ROG Strix Platinum PSU series is ready to power any rig a user can assemble, no matter what kind of graphics card they put under the hood. That’s where the patented GPU-First intelligent voltage stabilizer (IVS) comes into play.”
- “It ensures that even an overclocked graphics card always has the stable power flow it needs to perform at peak capacity during intense gaming sessions, providing up to 45% more stable flow to the GPU than without the stabilizer.”
- “And if users prefer a conventional CPU-focused voltage sensor, they can disconnect the Strix Platinum IVS cable.”
A look at how the technology can stabilize power:
ASUS on some of the PSU’s other features:
ROG Strix Platinum PSUs also feature a gallium nitride (GaN) MOSFET that pushes the envelope on power efficiency, reducing energy waste and boosting optimized power delivery by up to 30%, versus previous generations. Plus, the GaN MOSFET’s small size enables a simplified internal layout that provides more space for better heat dissipation, heavy-duty heatsinks and superior airflow.
Dual ball bearings on the PSU fan feature a lifespan of up to 80,000 hours, helping to ensure this power supply will keep going no matter how much gaming a user engages in. And when the PSU load is at 40% or lower with 0dB mode enabled, the fan will intelligently deactivate after achieving safe temperatures, keeping a rig as quiet as possible. Even when not in 0dB mode, the ROG Strix 1000W Platinum in particular emits less than 20 dB of noise — a low enough value to earn it an A+ Cybenetics Lambda certification, signifying an exceptionally quiet acoustic level.
This PSU series also packs 80 PLUS Platinum certification and Intel lab testing. This certification means that whether it is a light load or a heavy one, users always get at least 89% efficiency, thanks in part to high-end Japanese capacitors that can last up to twice as long as standard capacitors. The Platinum rating means highly efficient energy usage and a low temperature range, which leads to quiet acoustics and savings on energy bills. And high-performance copper pins on the upgraded PCIe connectors increase thermal conductivity and reduce connector temperatures.
Modular philosophy is a key part of what makes the ROG Strix Platinum series a next-generation power solution. Along with the impressive features of these PSUs, easy installation and organization are to be expected, thanks to flexible, etched modular cables ― which operate at up to 50°C below the safety limit. These cables also feature UL758 certification and meet UL1581 flame test standards, meaning DIY gaming PC builders can trust that the Strix Platinum can fulfill their needs in a way that is safe and sustainable.
An innovative CPU power cable is another DIY PC builder perk that ASUS has integrated into the ROG Strix Platinum series. It features a unique color scheme and special clip that makes it easy to identify. This way, users will immediately know which cable is meant to go to the processor.
Each Platinum series PSU also includes ROG Strix stickers ― so users can add a bit of custom flair to their PSU, choosing the vibe that best fits their aesthetic preferences. While these sleek, angular PSUs already pack ROG branding to make it clear that users are gaming with the best, a little extra color can go a long way toward illustrating a unique style.
