Cyberpunk 2077 Patch 2.13 Adds Support for AMD FSR 3 with Frame Generation and Intel XeSS 1.3
Image: CD PROJEKT RED
Patch 2.13, a new update for Cyberpunk 2077 and Phantom Liberty that delivers support for not only AMD FidelityFX Super Resolution 3 with Frame Generation, but also Intel’s Xe Super Sampling 1.3 technology, is now being rolled out for the PC version of the game, CD PROJEKT RED has announced. The new patch, which is exclusive to PC, also allows players on that platform to enable NVIDIA DLAA and DLSS Ray Reconstruction simultaneously.
Patch changes:
  • “Added support for AMD FidelityFX Super Resolution 3 with Frame Generation. More information can be found in this article on the Support website.”
  • “Added support for Intel Xe Super Sampling 1.3.”
  • “It will now be possible to enable both DLAA and DLSS Ray Reconstruction at the same time.”
  • “Added a new “Utilities” tab in Settings and moved HDD Mode, Hybrid CPU Utilization and AMD Simultaneous Multithreading (SMT) options there.”
  • “Other stability and visual fixes.”
CD PROJEKT RED writes:
Patch 2.13 for Cyberpunk 2077 and Phantom Liberty is being rolled out! It includes support for AMD FidelityFX Super Resolution 3 with Frame Generation. Please note that this update is PC-only!
Keep in mind that despite the version mismatch between PC and console, Cross Progression will still function properly.
