Razer BlackWidow V4 Pro 75% Is a Wireless, Hot-Swappable Gaming Keyboard with Built-In OLED Display and up to 40,000 Hz Polling Rate
Image: Razer
The BlackWidow V4 Pro 75%, a new wireless, hot-swappable gaming keyboard that Razer says was designed to elevate customization, control, and performance to new heights, featuring innovations that include 4K Hz Razer HyperPolling technology and a built-in OLED display, is available for pre-order now at Razer.com and RazerStores ahead of its release on September 24, 2024, Razer has announced. The keyboard, which also counts Razer Orange Tactile Switches Gen-3 and a hot-swappable design among its key features, can achieve up to 2,100 hours of battery life thanks to a special power saving mode, the company noted.
Pricing and availability:
  • $299.99 USD / €349.99 MSRP 
  • Pre-orders available now exclusively at Razer.com and RazerStores.
  • General Availability: Razer.com, RazerStores & Authorized Resellers – Starting from 24 September 2024.
Tech specs include:
  • Switch Type: Razer Mechanical Switches Gen-3 (Tactile)
  • Key Feel: Tactile and Quiet
  • Approximate size: 75% with function row and arrow keys
  • Lighting: Razer Chroma RGB
  • Wrist Rest: Yes, Magnetic Plush Leatherette
  • Onboard Memory: Hybrid on-board storage for up to 6 profiles
  • Media Keys: Razer Command Dial with 1 dedicated side button
  • Passthrough: None
  • Connectivity: Connect via Razer HyperSpeed Wireless (2.4 GHz), Bluetooth 5.1, or Type C
  • Keycaps: Doubleshot PBT Keycaps
Additional features:
  • 2” OLED Display
  • Razer Synapse enabled
  • Recycled 5052 Aluminum Alloy Top Case
  • PCR Plastic Bottom Case
  • PCB & Case Sound Dampening Foams included
  • Non-conductive Tape-enhanced PCB
  • Lubricated screw-in stabilizers with GPL 205 g
  • Warranty does not cover any internal damage caused by modifications to the keyboard.
  • 2-side underglow side strips
  • Up to 4,000 Hz wireless polling rate, up to 1,000 Hz wired polling rate
  • N-key rollover & Anti-ghosting
A promo for the new keyboard:
Razer on some of the BlackWidow V4 Pro 75%’s key features:
OLED Display with the Razer Command Dial – For Maximum Control and Customizability: The OLED display allows gamers to view key information like PC metrics, keyboard status, custom animations and audio meter visualization. It also enables gamers to adjust keyboard settings on-the-fly, including polling rate, lighting effects, power saving options and more. Paired with the Razer Command Dial, the keyboard offers gamers extensive control at their fingertips, with a range of functions including volume adjustment, zoom, track selector, and more.
True 4K Hz Wireless & Bluetooth 5.1 Connectivity – For Seamless Response and Connectivity: Featuring two highly requested features from the gaming community — Razer HyperSpeed Wireless technology and Razer HyperPolling technology at up to 4K Hz, the BlackWidow V4 Pro 75% delivers unmatched responsiveness and ultra-low latency.
Gamers can also seamlessly connect and toggle between up to 3 different Bluetooth devices, and even maintain these wireless connections while charging the keyboard via cable, ensuring continuous control and convenience. In addition, the BlackWidow V4 Pro 75% introduces a robust new Power Saving Mode, designed to maximize battery life by deactivating the OLED display and keyboard backlighting, and pausing communication with Razer Synapse. With it enabled, the keyboard achieves up to 2100 hours of battery life, providing stable, uninterrupted gameplay in its most energy-efficient state.
Hot-swappable Design with Pre-loaded Razer Orange Tactile Switches Gen-3: The BlackWidow V4 Pro 75% is compatible with both 3 and 5-pin mechanical switches, allowing users to easily customize their preferred key feel. The keyboard’s design, together with the pre-loaded Razer Orange Tactile Switches, has been crafted to provide a satisfying key feel and a sound signature that resonates with keyboard enthusiasts.
